08-24-2009 08:29 PM - edited 03-21-2019 01:27 AM
Attached is a diagram showing the current network configuration.
Currently the UC500 Wan port (192.168.0.250) is connected to the Dlink ADSL router. we have set up a static route on the DSL router to 10.1.1.0 using 192.168.0.250 as a gateway.
We're having problems pinging and routing trafic to the 10.1.1.x and 192.168.10.x network.
please note the UC500 has the default setup, nothing has been changed on it.
thanks
08-24-2009 08:51 PM
Is it not possible for you to put the modem in Bridge mode and let the UC-500 control the PPP session?
You can use CCA to do this and it is quite simple to do, its very usefull as well when you want to do VPN.
Cheers,
David.
08-24-2009 09:10 PM
Thanks David, Not sure if the Dlink could do bridge mode.
08-24-2009 11:02 PM
HI,
If you give me the model number of the router i will look into it for you, if it cant be done then we just do it the way your trying to do it now :)
Can you please provide the running config so i can look at how you have your interfaces setup, past into a txt file and make sure to remove any sensative informaiton out of there like username and passwords..
Cheers,
David.
