02-16-2011 11:13 PM - edited 03-21-2019 03:41 AM
We just configured a site to site VPN between our UC540 and remote site and we are passing data and voice traffic or so it appears. However, when I attempt to place my SPA504G at the remote location it does not download the configuration.
data network 192.168.22.0/24 voice network 10.1.1.0/24 ---------UC540--------Internet--------Firewall-------192.168.3.0/24
We have created site VPN that passes 192.168.22.0/24 and 10.1.1.0 traffic to 192.168.3./24
I can ping 192.168.3.0 network from 192.168.22.0 network
I can also ping 192.168.3.0 network from 10.1.1.0 network
and vise versa
What is missing? I can not get the Spa504G to phone to download the config from the UC540
Thanks in advance
Solved! Go to Solution.
02-16-2011 11:58 PM
What is the tftp source address? by default the UC540 is loopback0 with the 10.1.10.0/30 which is not part of the crypto traffic under your diagram.
you may want to add this network to your crypto ACL and deny it on your NAT configuration, or you could also change the ip tftp source-interface Loopback0 to ip tftp source-interface bvi100
Victor.-
02-16-2011 11:58 PM
Victor.-
02-17-2011 07:59 AM
Hi Victor,
My TFPT Server address according to CCA is 10.1.1.1
Thanks for the input, I was wondering if the 10.1.10.0/30 network needed to be setup to pass through our site to site vpn.
For your second suggestion, is there any repercussions or issues that could arise from changing the tftp source-interface Loopback0 to ip tftp source-interface bvi100 from a CCA stand point?
Thanks again,
02-17-2011 09:30 AM
If your tftp-source is set to Loopback0, the default address for Loopback0 is 10.1.10.2.
I would suggest that you leave the tftp server address, and add 10.1.10.0 to the VPN. Since you will also need to access this subnet for voicemail.
Thank you,
Darren
02-22-2011 06:13 PM
Thank you for your help this worked perfectly
