08-22-2011 04:23 PM - edited 03-21-2019 04:33 AM
I have just installed a SPA525G2 (firmware 7.4.5 / hardware version 2.0.0) and Im unable to upgrade the firmware. I have tried using both the web interface and using upgrade rule (tftp) using v7.4.6, v7.4.7 and v7.4.8. The web interface reports upgrade succesfull but the phone remains at the factory firmware level (v,7.4.5).
Help is much appreciated
08-24-2011 10:55 AM
Hi Cato,
The SPA525G2 hardware version 2 needs at least 7.4.7.
It will provide an error message if you attempt to install 7.4.5.
Do the following to upgrade:
1. Factory reset the phone
2. Use any method to upgrade to 7.4.7 or newer.
3. If the above fails, follow these steps:
review https://supportforums.cisco.com/docs/DOC-12743
review https://supportforums.cisco.com/docs/DOC-12989
Patrick
08-24-2011 04:23 PM
Thank you, flashing with the P01 (7.5.1) Image worked perfectly and I was able to flash with 7.4.8
But Im puzzled by the fact that a hardware version 2 SPA525 is delivered with 7.4.5 if it requires 7.4.7 or above to function properly?
Best regards,
Cato
