06-20-2010 10:58 AM - edited 03-21-2019 02:42 AM
Speed dial: press and hold idle line key
Will this functionality be enable with the 500S side car ?
07-14-2010 11:21 AM
If you have configured this in the extended function parameter of the phone (in phone tab) then you should see the same functionality in the sidecar.
07-14-2010 10:21 PM
Of course by configuring this functionality through the web interface it works well. But you can, on each phone of the spa5xx serie, by pressing 3 seconds on an unused line add manualy a spedd dial, on the 500S sidecar you cannot do it manually.
07-15-2010 09:15 AM
Thank you for the input, I'll submit a feature request on this issue.
