tls usage requirements
Luis Azedo
i can successfuly connect my spa504g to a kamailio server and get mwi notifications using UDP.
when i use tls, i successfuly register in the the server and also subscribe to mwi events.
i can make calls and srtp also works.
the problem is with kamailio server sending mwi notifications to spa504g when i use tls.
do i have to create a mini certificate and configure it in spa50g for tls mwi notifications to work ?
i don't know if the problm is with the server or with misconfiguration in spa504g.
the initial SUBSCRIBE event is successfulll and i can get a response (mwi light goes on if i have a vm).
the problem seems to be when the connection is initiated by the server.
any thoughts ? hints ?
thank you
Dan Lukes
Catch full log and debug messages
Debug and syslog Messages from the SPA3xx, SPA5xxG, SPA9xx, & WIP310 IP Phones
Just to be sure, catch the communication between exchange and phone as well (to verify that TLS is used all the times).
Installing and Using Wireshark for Capturing Network Traffic
It may reveal important informations to you.
thank you very much.
this helped me to identify the source of the problem in kamailio server.
Happy to hear it. Consider mark the thread as "solved". It may help others to found usefull advices.
