Hello Cisco faithful.We have a customer with a UC520 (8 user). They complain almost monthly that the time on the phones speeds up. Say the PC says "1:20" the phone will say "1:28". I have synced the UC to a local computer and assigned it as the N...
HiI just want to ask if the spa504g can be registered to microsoft lync 2010 directly? Does anyone here manage to do this? If not directly then what are the appliance needed?Thanks
Hello,What are your experiences with either: 1) a computer and a voip phone sharing the same ehternet cable to a UC320 (the computer is connected to the PC port on a voip phone).2) the computer being run to a UC320 on a dedicated ethernet cable to th...
The SPA525g2 Admin guide states: "A Cisco SPA525G or Cisco SPA525G2 user can create up to two ring tones froman MP3 audio file stored on a USB memory device. For instructions, see theCisco Small Business SPA525G and SPA525G2 SIP IP Phones User Guide,...
HiI updated the daylight savings dates on a Cisco525G2 and after restaring the phone now hangs at the Cisco logo screen.It goes through the start up, lights come on, the screen flashes and the cisco logo appears. And thats as far as it goes.I have tr...
Hey there, on behalf of a partner I have some questions/requests regarding PAP2T and SPA112: •1. I need a new SSL server license to the old PAP2t-eu unit since our old one has expired. (https)•2. I need the configuration guide(XML and TR-...
UC520 - Configuring Multiple DIDs with Different Password and RealmI use Unlimitel (Candadian VOIP provider).I have multiple DID and each DID has different password. and Different proxy server.For example:1- DID Number1: 519..... Password1 Prox...
Hi,Using SIP regsitration with flowroute. Have two DIDs registered as line 1 and line 2 using SIP registration. Line 1 works fine, Line two won't ring in. Flowroute indicates it's a problem with have two DIDs on a single Auth ID. Is there a worka...
I've been getting a UC540 running. I have had an SPA508G configured (working great) with it and recently got an SPA525G2 which I intended to setup as my first remote phone.The first thing I did was setup the SPA525G2 on the UC540's wireless network,...
Hi, Please help me solve the issue which I am facing with the below scenario. SITE A- UC560 Extn No range :1xx - ios: 15.1(4) SITE B- UC540 Extn No range :2xx - ios: 12.4(24) SITE C- UC540 Extn No range :3xx - ios: 12.4(24) SITE D- UC540 Extn No r...
UC320 - There are 6 users in a Hunt Group for incoming calls and the Main Receptionist answers the call, but the other 5 sets show a missed call even though it was actually answered. Any suggestions to overcome this?
Hi Guys,I have a SPA8800 configured with static ip address 192.168.1.2/24 and BE3000 with ip address 192.168.1.250 in the same network. I would like to connect a fax machine to SPA8800's fxs port however there are no PSTN lines connected to FXO port...
Hi,I was wondering what the default re-registration timer is in the UC320? I read another thread suggesting that there is no way to set this manually as you can in the UC500. We currently have a use case where a customer has an ASA5505 that will fa...
Hi,after update our UC520 to the Software Pack 8.6.1 I have a problem with IP Phone CP-7937G. I reboot the Phone and I get the message on the phone display "Change language" and the phone will automatically start again and again?I have install two lo...
