05-14-2011 10:46 PM - last edited on 03-25-2019 10:57 PM by ciscomoderator
I have a potential customer is a doctor's office. They want to know if the voicemail can accept the voicemail and have the caller dial the call back number, the information either to be sent to the doctor via email or text message.
The main reason would be the caller ID would not be good enough because it would not show the extension number from the hospital, the voicemail is not clear enough.
What about text to speech? Cisco solution or third party?
Thanks!
John
05-15-2011 03:44 PM
Hi John,
The features I am aware of are the following:
I am still searching for the third party company who does the speech-to-text for CUE, there are Cisco and third party ones for Cisco Unity, however I have only ever seen one for Cisco Unity Express (but I am sure there are more out there).
As soon as I find the company I will post it up here for you.
Cheers,
David.
05-15-2011 04:07 PM
Hi, David,
Thanks for your reply.
One problem is the caller ID usually only showes the caller's Hospital or Nursing home's main number, it would not have the extension number. So this information might need to be engered manually through phone's dial pad, like the old day's we were sending the pager. The problem with voicemail is because of the accent sometime requires voicemail to be listened multiple times before we can capture the right phone number.
Any of you have any experience with IPCelerate? Do they still provide solution for UC500?
Thanks for your input!
John
