05-14-2013 02:07 PM - edited 03-21-2019 07:21 AM
We are having a cisco UC520 with UC software pack 8.6.1, just bought from a company with is bankrupt
UC520-32U-8FXO-k9
uc500-advipservicepackk9-mz.151-4.m5
CUE
GUI 4.2.0.0
ios 15.1(4) M5
The system is running with GUI 4.2 is this correct? And when updating the VM system it's stopping at 20 minutes with the error VM up grade failed, is this a known error ? Or how do we upgrade to CUE 8 ? or do I misread the information, or is somebody the right link to make the system factory default with the right software levels, we have UC software pack 8.6.1 availibly
Thanks for the help !
Solved! Go to Solution.
05-14-2013 02:18 PM
I would recommend engaging a Cisco Partner/Consultant or getting a contract on the box and working with TAC.
It sounds like you are trying to upgrade CUE with CCA and it is failing... it will probably have to be attempted in CLI.
I am not sure if that is the current web gui version, but just about no one uses the web gui anyway.
CCA (officially Cisco supported) or CLI (Experts) are the preferred configuration tools.
-Dan
Please rate useful posts.
05-14-2013 02:18 PM
-Dan
05-15-2013 03:24 PM
Go to sbkb.cisco.com and look for software upgrade CLI. There is a nice document on how to do an upgrade via CLI.
