02-01-2013 10:39 AM
I recently bought a cisco 1841 with an AIM-VPN/SSL-1 module. When the routers boots i get the following output stating that the module is unsupported. From what i can se i am running the correct version of IOS along with supported hardware. What could be wrong, any suggestions?
/Mattis
ystem Bootstrap, Version 12.3(8r)T6, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x0f
GIO FPGA version 0x128
c1841 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0x1432c98
Self decompressing the image : ###################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
000504 UNKNOWN AIM
0X00020000 Crypto module pools
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 7136647 bytes to IO Memory.
PMem allocated: 118489088 bytes; IOMem allocated: 15728640 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(25g), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 22-Aug-12 03:41 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 1841 (revision 4.1) with 115712K/15360K bytes of memory.
Processor board ID FHK084220VV
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
984816K bytes of ATA CompactFlash (Read/Write)
Press RETURN to get started!
*Feb 1 20:23:29.891: %AIM-2-AIMUNSUPP: AIM type 0x504 is not supported by this platform.sslinit fn
*Feb 1 20:23:33.311: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Feb 1 20:23:33.315: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Feb 1 20:23:36.155: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 1 20:23:36.411: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Feb 1 20:23:36.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to up
*Feb 1 20:23:36.867: %SYS-5-RESTART: System restarted --
*Feb 1 20:23:36.871: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Feb 1 20:23:37.027: %SYS-6-BOOTTIME: Time taken to reboot after reload = 61 seconds
*Feb 1 20:23:37.175: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Feb 1 20:23:37.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
Router>
Router>
Router>
Router>
Router>en
Router#sho ver
Router#sho dia
Router#sho diag
Router#sho diag
Slot 0:
C1841 2FE 2SLOT Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:05:00 ago
EEPROM contents at hardware discovery:
Chassis MAC Address : 0011.21a9.142e
MAC Address block size : 34
PCB Serial Number : FOC08391NEZ
Hardware Revision : 4.1
Part Number : 73-8191-04
Board Revision : D0
Top Assy. Part Number : 800-23434-01
Deviation Number : 0
Fab Version : 04
CLEI Code : IPM7F00CRA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : CISCO1841
Version Identifier : VN/A
Processor type : 86
Chassis Serial Number : FHK084220VV
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C3 06 00 11 21 A9 14 2E 43 00 22 C1 8B 46
0x10: 4F 43 30 38 33 39 31 4E 45 5A 40 04 1B 41 04 01
0x20: 82 49 1F FF 04 42 44 30 C0 46 03 20 00 5B 8A 01
0x30: 88 00 00 00 00 02 04 C6 8A 49 50 4D 37 46 30 30
0x40: 43 52 41 03 00 81 00 00 00 00 04 00 CB 89 43 49
0x50: 53 43 4F 31 38 34 31 89 56 4E 2F 41 D9 02 C1 40
0x60: 09 86 C2 8B 46 48 4B 30 38 34 32 32 30 56 56 FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
AIM Module in slot: 0
Hardware Revision : 1.0
Top Assy. Part Number : 800-27302-01
Board Revision : A0
Deviation Number : 9-4123
Fab Version : 02
PCB Serial Number : FOC12031E70
RMA History : 00
Product (FRU) Number : AIM-VPN/SSL-1
Version Identifier : V01
0x00: 04 FF 40 05 04 41 01 00 C0 46 03 20 00 6A A6 01
0x10: 42 41 30 80 00 09 10 1B 02 02 C1 8B 46 4F 43 31
0x20: 32 30 33 31 45 37 30 03 00 81 00 00 00 00 04 00
0x30: CB 8D 41 49 4D 2D 56 50 4E 2F 53 53 4C 2D 31 89
0x40: 56 30 31 00 D9 02 40 C1 FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
