Can you have both policy-based and route-based VPNs on same ASA?
baskervi
I am just about to add a route-based VPN onto an ASA that already has several policy-based VPNs. I presume this won't be a problem, but I couldn't find any documentation on Cisco's web site for any limitations of two types of VPNs on the same device. Is anyone aware of a problem? Thanks
I've not seen any documentation on it either nor have I tried it yet, but I would imagine that it should work fine. As long as the crypto map acl and the static/dynamic route used on the VTI/route based VPN doesn't overlap they should co-exist ok fine.
I'm going to take this as a solution. I'm suspecting you are correct in this. Thanks
