Cisco ASA 5512-x L2TP IPSEC vpn tunnel up, ping to devices work, but no other connection.
madismannik
I've successfully configured Cisco ASA 5512-x device. This includes internal networks connection, NAT and almost VPN.
Now the problem is that I can establish VPN tunnel from outside network. I can ping from vpn to inside network devices and vice-versa. I can resolve network names of internal devices and so on. When i try to use Remote desktop access or access to internal webpages, it seems, that everything is restricted or denied.
My config :
interface Redundant1
member-interface GigabitEthernet0/0
member-interface GigabitEthernet0/1
nameif Outside
security-level 0
ip address g.g.g.i 255.255.255.192
interface Redundant5
description Inside Interface
member-interface GigabitEthernet0/2
member-interface GigabitEthernet0/3
nameif Inside
security-level 100
ip address x.x.x.x 255.255.255.0
ipv6 address autoconfig
ipv6 enable
ftp mode passive
clock timezone EET 2
dns domain-lookup Inside
dns server-group DefaultDNS
name-server x.x.x.c
name-server x.x.x.y
domain-name MyNet.ee
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network NETWORK_OBJ_x.y.c.0_24
subnet x.y.c.0 255.255.255.0
object network Gateway
host g.g.g.g
description Gateway address
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object udp
protocol-object tcp
object-group network MyNet
description MyNet  Internal networks
network-object x.x.x.0 255.255.255.0
network-object k.k.k.0 255.255.255.0
network-object t.t.t.0 255.255.255.0
network-object p.p.p.0 255.255.255.0
network-object pt.pt.pt.0 255.255.255.0
object-group network VPN-network
description VPN Users Network Group
network-object object NETWORK_OBJ_x.y.c.0_24
object-group network DM_INLINE_NETWORK_2
group-object MyNet
group-object VPN-network
object-group service Inside-outside
description Inside-Outside policy for internet access
service-object tcp-udp destination eq domain
service-object tcp-udp destination eq www
service-object tcp destination eq domain
service-object tcp destination eq https
service-object object 7046
service-object object 8008
service-object object MS-DS-SMB
service-object object RDMI-SHO-HTTP
service-object tcp destination eq pop3
service-object tcp destination eq smtp
access-list Inside_access_in extended permit ip object-group VPN-network object-group MyNet
access-list Inside_access_in extended permit ip object-group MyNet object-group VPN-network
access-list Inside_access_in extended permit ip object-group MyNet object-group MyNet
access-list Inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 object-group MyNet any
access-list Inside_access_in extended permit ip any object-group MyNet
access-list Inside_access_in extended permit ip any any
access-list global_access extended permit ip any object-group VPN-network
access-list global_access extended permit ip object-group VPN-network any
access-list global_access extended permit object-group Inside-outside any object-group MyNet
access-list global_access extended permit ip any object-group MyNet inactive
access-list global_access extended permit ip any any inactive
access-list ACL_IN extended permit ip object-group MyNet object-group VPN-network
access-list tcp_bypass extended permit tcp x.x.x.0 255.255.255.0 any
access-list tcp_bypass extended permit tcp k.k.k.0 255.255.255.0 any
access-list tcp_bypass extended permit tcp t.t.t.0 255.255.255.0 any
access-list tcp_bypass extended permit tcp p.p.p.0 255.255.255.0 any
access-list tcp_bypass extended permit tcp pt.pt.pt.0 255.255.255.0 any
access-list Inside_access_out extended permit ip any object-group VPN-network
access-list Inside_access_out extended permit ip object-group MyNet object-group MyNet
access-list Inside_access_out extended permit ip object-group MyNet any
access-list Inside_access_out extended permit ip any any
access-list Outside_access_out extended permit ip object-group VPN-network object-group MyNet
access-list Outside_access_out extended permit ip object-group MyNet object-group VPN-network
access-list Outside_access_out extended permit object-group Inside-outside object-group MyNet any
access-list Outside_access_out extended permit ip object-group MyNet any
access-list Outside_access_in extended permit ip object-group MyNet object-group VPN-network
access-list Outside_access_in extended permit ip object-group VPN-network object-group MyNet
access-list Outside_access_in extended permit object-group Inside-outside any object-group MyNet
access-list Outside_access_in extended permit ip any object-group MyNet inactive
access-list Internal-VPN standard permit x.y.c.0 255.255.255.0
ip local pool VPN-Pool x.y.c.50-x.y.c.150
nat (any,any) source static VPN-network VPN-network destination static MyNet MyNet
nat (Inside,any) source static MyNet MyNet destination static MyNet MyNet
nat (Inside,Outside) after-auto source dynamic MyNet interface
access-group Outside_access_in in interface Outside
access-group Outside_access_out out interface Outside
access-group Inside_access_in in interface Inside
access-group Inside_access_out out interface Inside
access-group global_access global
route Outside 0.0.0.0 0.0.0.0 g.g.g.1 1
route Inside k.k.k.0 255.255.255.0 x.x.x.254 1
route Inside t.t.t.0 255.255.255.0 x.x.x.254 1
route Inside p.p.p.0 255.255.255.0 x.x.x.254 1
route Inside pt.pt.pt.0 255.255.255.0 x.x.x.254 1
route Inside 0.0.0.0 0.0.0.0 x.x.x.1 tunneled
dynamic-access-policy-record DfltAccessPolicy
aaa-server UM-Radius protocol radius
aaa-server UM-Radius (Inside) host x.x.x.y
key *****
no user-identity enable
user-identity default-domain LOCAL
no user-identity action mac-address-mismatch remove-user-ip
http server enable
crypto ipsec ikev1 transform-set ESP-AES256-SHA1_TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES256-SHA1_TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES128-SHA1_TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES128-SHA1_TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES256-SHA1 esp-aes-256 esp-sha-hmac
crypto dynamic-map DYN_OUTSIDE 10000 set ikev1 transform-set ESP-AES256-SHA1_TRANS ESP-AES128-SHA1_TRANS ESP-AES256-SHA1
crypto dynamic-map DYN_OUTSIDE 10000 set reverse-route
crypto map MAP_OUTSIDE 10000 ipsec-isakmp dynamic DYN_OUTSIDE
crypto map MAP_OUTSIDE interface Outside
crypto ikev1 enable Outside
crypto ikev1 ipsec-over-tcp port 10000
crypto ikev1 policy 1000
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 2000
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 3000
encryption aes
hash sha
group 2
lifetime 86400
group-policy EMPLOYEES_L2TP_IPSEC internal
group-policy EMPLOYEES_L2TP_IPSEC attributes
dns-server value x.x.x.y x.x.x.c
vpn-tunnel-protocol l2tp-ipsec
default-domain value MyNet.ee
tunnel-group DefaultRAGroup general-attributes
address-pool (Inside) VPN-Pool
address-pool VPN-Pool
authentication-server-group UM-Radius
authentication-server-group (Inside) UM-Radius
authorization-server-group UM-Radius
accounting-server-group UM-Radius
default-group-policy EMPLOYEES_L2TP_IPSEC
tunnel-group DefaultRAGroup ipsec-attributes
ikev1 pre-shared-key *****
isakmp keepalive disable
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
I have been on this issue for few weeks now.
Thanks for advance.
15 Replies 15
madismannik
Hi Sachin,
It was none of those bugs, actuall problem was caused by our virus protection software. It is somehow weird because few computers with virus protection can connect to VPN and in the meantime identical settings computer cannot connect to VPN.
Anyways it seems, that Cisco team has been really helpful for me.
I do actually have another conecern with this firewalls config, but this is related to FTP connections and I belive I should open another case and mark this one solved.
Thanks again.
