IKEv2 S2S between ISR 886VA and ASA 5510
Exonix
I try to configure the IKEv2 tunnel between ASA 5510 and ISR 886VA using this article, scenario one. I have configured it, but i have a few questions:
1) what is the address 10.10.10.1 ? there is no such IP address on the scheme:
2) how can i define which traffic to send through the tunnel? For example, there is a network behind the ASA 10.255.10.0/24, I would like to access it from ISR network 10.254.1.0/24, but I don't need to encrypt the traffic to network 10.255.30.0/24.
My scheme:
Thank you in advance!
30 Replies 30
unfortunately it didn't help.
from ASA:
ASA1# traceroute 10.254.1.133
Tracing the route to 10.254.1.133
1 lan.fra1.domain.local (201.1.1.1) 0 msec 0 msec 0 msec
2 * * *
3 * * *
4 * * *
5 * * *
from Router:
#traceroute 10.255.10.160
Tracing the route to 10.255.10.160
VRF info: (vrf in name/id, vrf out name/id)
1 XXX.XXX.XXX.XXX 20 msec 16 msec 20 msec
2 XXX.XXX.XXX.XXX !H !H !H
the clients have the same issue.
Can you please provide some debug output "debug crypto ikev2"?
Ta
Ta
debug shows nothing. it is silent
You enabled this debug on the router? and then attempted to establish a vpn by generating traffic?
If nothing is in the debug of the router either traffic isn't matching the acl and therefore triggering the tunnel or the crypto map is enabled on the wrong interface?
yes, I enabled the debug and then generated a traffic but nothing has been shown.
You saw my config. The ACL is good, but interface... I enable all maps or rules on the Dialer0 interface. Also I tried to enable it on VLAN1 interface - still the same: no traceroute, no logging...
You previously run a traceroute from the router itself, that doesn't guarantee that the source IP address is within the crypto map subnet. Can you ping and traceroute 10.255.10.x from a device within the range 10.254.1.x. Please provide debugs and outputs.
I did tracert from a Windows client in 10.255.10.0/24 and another client from 10.254.1.0/24 too - always the same. It comes to router or ASA and stops. and there is no any debug log too while the tracert.
Can you provide the output from "show ip route"
ISR#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is YYY.YYY.YYY.YYY to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via YYY.YYY.YYY.YYY
      10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
C        10.254.1.0/24 is directly connected, Vlan1
L        10.254.1.1/32 is directly connected, Vlan1
C        10.254.2.0/24 is directly connected, Vlan2
L        10.254.2.1/32 is directly connected, Vlan2
S        10.254.10.0/24 [1/0] via 10.254.1.4
S        10.255.9.11/32 [1/0] via 10.254.1.8
      XX.0.0.0/32 is subnetted, 1 subnets
C        XXX.XXX.XXX.XXX is directly connected, Dialer0
      YY.0.0.0/32 is subnetted, 1 subnets
C        YYY.YYY.YYY.YYY is directly connected, Dialer0
      172.66.0.0/24 is subnetted, 1 subnets
S        172.66.0.0 [1/0] via 10.254.1.4
      192.168.178.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.178.0/24 is directly connected, Vlan3
L        192.168.178.1/32 is directly connected, Vlan3
In my previous Router's config I removed some VLANs, thinking they are not matter.
ASA1# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
Gateway of last resort is ZZZ.ZZZ.ZZZ.ZZZ to network 0.0.0.0
C    ZZZ.ZZZ.ZZZ.ZZZ 255.255.255.248 is directly connected, WAN
S    172.65.0.0 255.255.255.0 [1/0] via 10.255.10.1, LAN-MSP
S    10.100.0.0 255.255.255.0 [1/0] via 10.255.10.1, LAN-MSP
S    10.255.10.76 255.255.255.255 [1/0] via 10.255.10.1, LAN-MSP
S    10.144.90.11 255.255.255.255 [1/0] via 10.255.10.1, LAN-MSP
S    10.249.0.0 255.255.255.0 [1/0] via 10.255.10.1, LAN-MSP
C    10.255.3.0 255.255.255.0 is directly connected, management
S    10.255.9.0 255.255.255.0 [1/0] via 10.255.3.1, management
C    10.255.10.0 255.255.255.0 is directly connected, LAN-MSP
S*   0.0.0.0 0.0.0.0 [1/0] via ZZZ.ZZZ.ZZZ.ZZZ, WAN
don't think of the 172 networks. it's a rudiment.
The router config your previously provided, is it the full complete configuration?
It references "ip nat inside source list 101 interface Dialer0 overload" but acl 101 is not in the config.
I assume you can ping the public ip address of the ASA from the router and the routers' lan?
I would like to clean router's config. for example a think of where to move the current VPN to remove the portforwarding forever. I will reconfigure the Router a little bit and then send the full config.
here are the full configs of the router and of the firewall
interface Vlan1
description LAN
no crypto map vpn
interface Dialer0
description VDSL TELEKOM
crypto map vpn
ip access-list extended vpn
permit ip host 10.254.1.1 187.XXX.XXX.XX1
ip access-list ext 101
1 deny ip host 10.254.1.1 187.XXX.XXX.XX1
#debug crypto ikev2
#ping 187.XXX.XXX.XX1 source 10.254.1.1
@a.alekseev wrote:
interface Vlan1
description LAN
no crypto map vpn
interface Dialer0
crypto map vpn
#debug crypto ikev2
Sending 5, 100-byte ICMP Echos to 187.XXX.XXX.XX1, timeout is 2 seconds:
Packet sent with a source address of 10.254.1.1
Success rate is 80 percent (4/5), round-trip min/avg/max = 28/31/32 ms
Ok.
But when I ping any hosts behind the ASA - it still doesn't work:
tracert 10.255.10.160
Tracing route to 10.255.10.160 over a maximum of 30 hops
  1     1 ms     1 ms     1 ms  10.254.1.1
  2    18 ms    18 ms    18 ms  62.YYY.YYY.YYY
  3    62.YYY.YYY.YYY  reports: Destination host unreachable.
I think it is because the VPN map doesn't define this network, does it?
Exonix
this article doesn't include any information about routing configuration moreover it has a wrong ACL. Here is a part my working config:
ISR 886 VA:
crypto ikev2 proposal L2L-Prop
 encryption 3des
 integrity sha1
 group 2 5
crypto ikev2 policy L2L-Pol
 proposal L2L-Prop
crypto ikev2 keyring L2L-Keyring
 peer vpn
  address 187.XXX.XXX.XX1
  pre-shared-key local *********
  pre-shared-key remote *********
crypto ikev2 profile L2L-Prof
 match identity remote address 187.XXX.XXX.XX1 255.255.255.255
 identity local key-id S2S-IKEv2
 authentication remote pre-share
 authentication local pre-share
 keyring local L2L-Keyring
crypto ipsec transform-set ESP-AES-SHA esp-aes esp-sha-hmac
mode tunnel
crypto map vpn 10 ipsec-isakmp
 set peer 187.XXX.XXX.XX1
 set transform-set ESP-AES-SHA
 set ikev2-profile L2L-Prof
 match address vpn
interface Dialer0
 crypto map vpn
ip route 10.255.10.0 255.255.255.0 187.XXX.XXX.XX1
 permit ip 10.254.1.0 0.0.0.255 10.255.10.0 0.0.0.255
access-list 101 deny   ip 10.254.1.0 0.0.0.255 10.255.10.0 0.0.0.255
access-list 101 permit ip 10.254.1.0 0.0.0.255 any
ASA 5510:
interface Ethernet0/0
 duplex full
 nameif WAN
 security-level 0
 ip address 187.XXX.XXX.XX1 255.255.255.248
interface Ethernet0/1
 duplex full
 nameif LAN-MSP
 security-level 100
 ip address 10.255.10.99 255.255.255.0
object network LAN-MSP
 subnet 10.255.10.0 255.255.255.0
object network OFFICE
 subnet 10.254.1.0 255.255.255.0
access-list vpn extended permit ip 10.255.10.0 255.255.255.0 10.254.1.0 255.255.255.0
nat (LAN-MSP,any) source static LAN-MSP LAN-MSP destination static OFFICE OFFICE
crypto ipsec ikev2 ipsec-proposal ESP-AES-SHA
 protocol esp encryption aes
 protocol esp integrity sha-1
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map dmap 1 match address vpn
crypto dynamic-map dmap 1 set ikev2 ipsec-proposal ESP-AES-SHA
crypto map vpn 1 ipsec-isakmp dynamic dmap
crypto map vpn interface WAN
crypto ca trustpool policy
crypto ikev2 policy 1
 encryption 3des
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 enable WAN
group-policy Site-to-Site internal
group-policy Site-to-Site attributes
 vpn-tunnel-protocol ikev2
tunnel-group S2S-IKEv2 type ipsec-l2l
tunnel-group S2S-IKEv2 general-attributes
 default-group-policy Site-to-Site
tunnel-group S2S-IKEv2 ipsec-attributes
 ikev2 remote-authentication pre-shared-key *******
 ikev2 local-authentication pre-shared-key *******
