iPhone IPSec problems
MGTK_Cisco
Hello.
The problem is: when I'm trying to connect it asks login/password, accepts them and then just drops. The on/off switch turns off. No error messages, nothing at all. Settings are correct for sure. I've tried on android and windows phone. All iOS devices have this trouble. iOS version is 6.0.1. What's the problem? Can you help me, please?
5 Replies 5
anujsharma85
Can you check if it is possible to grab any sort of logs from VPN client in the phone?
Along with this please run debug crypto isakmp and ipsec from VPN server at the same. If this issue then try running debug crypto isakmp / ipsec 200.
Anuj
"Session is being torn down. Reason: Phase 2 Mismatch"
Thats what ASA told me.
Please post the transform set used for this vpn.
With Regards,
Safwan
Ok, I think I understood the problem.
iPhone is trying to connect with 3DES/AES128. But I have only DES on my ASA. (there's a problem in Russia with AES128/3DES...)
Is there any way to use DES on my iPhone? AnyConnect is also unavailable...
Either you have to use 3des or you have to use pptp or anyconnect.
With Regards,
Safwan
Don't forget to rate helpful posts
