Is ICMP required for site-to-site VPN
paulio.hughes
I am in the process of setting up a site to site VPN connection with a Cisco 1841 with the AIM-VPN-SSL-1 module and an NEC IX2015. We are using a GRE tunnel with IPSec
The problem we are having is the NEC router will not repsond to ICMP packets (and there isn't a way to make it respond). Will this cause any problems with the tunnel?
Thanks!
Paul
Jennifer Halim
Don't believe it will cause any problem. The most you can't do is not being able to ping to test connectivity. Other than that, the IPSec LAN-to-LAN tunnel should work just fine.
Jennifer Halim
Thanks for the answer! much appreciated
