Layer2 site2site(asa)
stimpy182
Dear,
for a customer setup we are trying to configure a site to site vpn with a asa5505 and a asa5520.
Both side's need to be in the same subnet so it with be a Layer2 VPN(bridge).
I've looked around but can't seem to find anything about it. Does anybody have experience with this or an example?
I have here 2 asa5505 firewall on my desk to test the vpn connection.
PS: i now it's beter to route the traffic instead of bridge the traffic but it's only as a backup line so no production will be goiing over the line.
2 Accepted Solutions
If you really need L2, then you have to deploy two routers (one on each site) and configure an IPSec/GRE-Tunnel between them. There you can bridge your traffic.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
It is not possible
ASA does not support L2TP client configuration, so you can't have L2TP between 2 ASAs.
Jennifer Halim
This is not a supported configuration on the ASA.
stimpy182
If i read around it says it's possible to make a L2TP tunnel. but can't find it site-to-site.
So it's not possible with the asa but with a regular router it would be possible?
Ps : it's not supported or it's not possible ;-). because it would only be as a backup line(max. 4h SLA)
          There will be a Layer-2 tunnel provided by the provider, but they wan't a backup over internet when the line is down.
It is not possible
