Spoke (remote-vpn) to spoke (l2l-vpn) though hub ASA: ipsec-spoof
Jaaazman777
Hello!
We have one remote client and one remote office.
Client use remote vpn to connect to central ASA (remote net 192.168.10.0/24)
remote office uses l2l IPsec to connect to the same ASA inteface. (l2l remote net 10.2.2.0/24)
We try to connect this remote vpn client to l2l remote site with no luck
- crypto-acl from both sides are ok
- nat0 is ok
- we also have command same-security-traffic permit intra-interface, which permits communication between peers connected to the same interface
from packet-tracer input outside icmp 192.168.10.1 0 0 10.2.2.1 detail we see
Action: drop
Drop-reason: (ipsec-spoof) IPSEC Spoof detected
How can we solve this problem?
Jennifer Halim
Do you mind sharing your config, thx.
