1841 remote access vpn not working right. (nat/split tunnel issue maybe?!?)
isupport4u
hello there,
this is very strange, I have setup a remote access on our 1841 device, with split tunnel.
now i am able to connect via the vpn tunnel, and even ping and telnet into the cisco device, but when i try to ping any device past the 1841, the ping fails and no traffic is even been encrypted to go over the vpn traffic (looking at the vpn client statistics).
From the ciscos side, pings to the vpn client is failing, yet i see the vpn client in the routing table.
Any ideas to what i may be missing would be greatly appriciated.
J.
Here is my config:
cisco1841#sh run
Building configuration...
Current configuration : 7682 bytes
version 12.4
service password-encryption
hostname cisco1841
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $*********************
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 smtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip inspect name DEFAULT100 icmp
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip ips notify SDEE
crypto pki trustpoint TP-self-signed-2667044945
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2667044945
revocation-check none
rsakeypair TP-self-signed-2667044945
crypto pki certificate chain TP-self-signed-2667044945
certificate self-signed 01
xxxxxxxx
x
x
x
x
  quit
username       xxxxxxx
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp client configuration group XXXXXXX
key **************
dns 192.168.1.9 4.2.2.2
domain ***********
pool SDM_POOL_1
acl 150
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface FastEthernet0/0
description $ETH-LAN$$INTF-INFO-FE 0$$FW_INSIDE$LAN
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$WAN
ip address 69..x.x. 255.255.255.192
ip access-group 102 in
ip verify unicast reverse-path
ip nat outside
ip inspect DEFAULT100 out
duplex auto
speed auto
interface FastEthernet0/0/0
shutdown
interface FastEthernet0/0/1
shutdown
interface FastEthernet0/0/2
shutdown
interface FastEthernet0/0/3
shutdown
interface Vlan1
no ip address
ip local pool SDM_POOL_1 192.168.2.2 192.168.2.12
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 69.x.x.x
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/1 overload
access-list 100 deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip any any
access-list 150 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
route-map SDM_RMAP_1 permit 1
match ip address 100
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
line aux 0
line vty 0 4
transport input telnet ssh
line vty 5 15
scheduler allocate 20000 1000
end
cisco1841#
andamani
the configuration is fine.
Can you please check the internal network behind the router know the route to get to the client.I.e. route on L3 device, if any, for vpn client pointing to router.
Also you mentioned that the traffic is not passing through the VPN client when you try to ping. what do you see there? no increase in packets encrypt counter  in the statistic of VPN client.
Do you see the network 192.168.1.0 in the secured routes of the route details of VPN client?
Hope this helps.
Anisha
P.S.: please mark this post as answered if you feel your query is resolved. Do rate helpful posts.
Hello Anisha,
Thanks for the reply, to answer your questions:
     - Yes the router is able to ping all internal resources with no problem, all clients are pointing to the router as there gateway.
     - When i try to ping over the vpn tunnel, there are no packets that are being encrypted. it looks like the packet are going to the internet instead.
     The only device i am able to ping and get packet increments is the routers ip address only, any other device i try to ping, no packet are being encrypted (no route to host i see on my device), yet in the routing table i am able to see the vpn clients ip address, but cannot ping them.
     - Yes i do, which i why this is strange for me.
Thanks in advance and let me know if you have any other ideas?
Jonathan
Can you please attach the screen shot of the Route print from the client
Ping the internal host and check if the following counter is increasing:
Vpn client > Status > Statistics > Tunnel Details > packets > Encrypted and Decrypted and bypassed.
Also checkif the firewall on the client is dropping the packets. Try turning it off.
Hope this helps.
Regards.
Anisha
P.S.: please mark this thread as answered if you feel your query is resolved. Do rate helpful posts.
Hey there,
There is only a count in the bypassed, when trying to ping internal resources, except when pinging the router, only and only than i see packet encrypting and decrypting.
There is no firewall on the clients side.
J.
