04-25-2013 09:51 AM
The tunnel connection is establishing correctly but when i change the priority in he hsrp configuration of my gig 0.1 interface to be the active on this router the cellular 0/0/0 interface goes down, by the way this is going to be my redundancy.
This is the configuration that i got
chat-script lte "" "AT!CALL1" TIMEOUT 60 "OK"
crypto isakmp policy 2
authentication pre-share
crypto isakmp key cisco123 address 67.21.161.218
crypto ipsec transform-set ASA-IPSEC esp-des esp-sha-hmac
crypto map bars01 1 ipsec-isakmp
description Tunnel toCOrp
set peer 67.21.161.218
set transform-set ASA-IPSEC
set pfs group1
match address 100
interface GigabitEthernet0/0.1
description Legacy vlan
encapsulation dot1Q 1 native
ip address 10.141.116.252 255.255.255.0
standby 0 ip 10.141.116.250
standby 0 priority 105
standby 0 preempt
ip tcp adjust-mss 1395
interface Cellular0/0/0
ip address 166.258.14.27 255.255.255.0
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 2147483
dialer string lte
dialer-group 1
async mode interactive
crypto map bars01
ip nat inside source route-map nonat interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip route 67.21.161.218 255.255.255.255 Cellular0/0/0
access-list 100 permit ip 10.141.116.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 permit ip 10.141.116.0 0.0.0.255 140.140.251.0 0.0.0.255
access-list 100 deny ip any any
access-list 110 deny ip 10.141.116.0 0.0.0.255 140.140.251.0 0.0.0.255
access-list 110 deny ip 10.141.116.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 permit ip 10.141.116.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 110
I will appreciate your help
Thanks a lot
04-29-2013 05:59 PM
Hi David,
As per the mentioned issue you might be seeing the below logs on the logging console.
Apr 2 14:49:49.209: LINEPROTO-5-UPDOWN Line protocol on Interface Cellular0/1/0, changed state to down Apr 2 14:49:53.237: LINK-3-UPDOWN Interface Cellular0/1/0, changed state to down Apr 2 14:50:15.121: LINK-3-UPDOWN Interface Cellular0/1/0, changed state to up Apr 2 14:50:16.121: LINEPROTO-5-UPDOWN Line protocol on Interface Cellular0/1/0, changed state to up
Please try the below workaround.
step 1: create an acl to permit your public ip to any
access-list 147 permit ip host
eg:
access-list 147 permit ip host 166.258.14.27 any
apply the acl out bound on the interface
step 2: Apply the acl out bound on the interface
ip access-group 147 out
The ISP expects your public ip as the source and hence it resets the interface.
hope it helps !!!!!!!!! in resolving your issue.
Thanks and regards,
Rohan
