2 Problems with 7.2(1) Upgrade
Adam Frederick
Level 3
Level 3
I have upgraded to Version 7.2(1) on my PIX515e and am having a few problems.
First off, when a home user connects remotely to the PIX using IPSec VPN w/ Pre-Shared Keys, it now asks for a User/Password combo, and the VPN will establish if the user enters a username/pass combo entered in the PIX config, I would prefer not to do this, I would like to just continue using Pre-Shared Key w/ PIX IP address in the VPN Client. Any suggestions? I have compared the config with my 7.0(6) config and nothing has changed.
Second problem, the PIX is now rebooting sporadically. I have isolated this to the 7.2(1) image because when I downgrade back to 7.0(6), the PIX ran fine for days, but 7.2(1) will run for a few hours and reboot itself. This PIX has 128MB DRAM and 16MB Flash.
Any input would be greatly appreciated!
Adam
thomas.chen
Level 6
Level 6
Workaround for this behaviour is to disable the esmtp inspect. This will not let the firewall reboot.
Enter the configure terminal mode and enter the following commands.
policy-map global_policy
class inspection_default
no inspect esmtp
The Resolution to this problem is to upgrade it to the interm release 7.2.1.17.
