2600 router ras speed problem
PistuPAPP
I use a 2610 router as ras router and I met with the following problem:
When I ping this router with bigger packets, the speed seems OK.
The speed of modem connection is 33600.
When I use the telnet or any tcp, the speed dramatically decreases.
Here is the configuration of the router.
Can anybody help me?
router#sh run
Building configuration...
Current configuration:
version 12.0
service exec-callback
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname router
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization exec default local if-authenticated
aaa authorization network default local
enable secret 5 **************.
username test1 callback-dialstring "" password 7 *****************
username test1 autocommand exit
ip subnet-zero
isdn switch-type basic-net3
chat-script reset "" "ATZ" OK "AT&FS0=1&C1&D3&B1&H1&R2&M4&K1&W" OK
chat-script cb ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT\T" TIMEOUT 60 CONNECT \c
interface Ethernet0/0
ip address 10.254.1.2 255.255.255.0
no ip directed-broadcast
interface BRI0/0
ip unnumbered Ethernet0/0
encapsulation ppp
dialer idle-timeout 1800 either
dialer enable-timeout 20
dialer-group 1
peer default ip address pool isdn
ppp callback accept
ppp authentication chap
ppp multilink
ppp timeout retry 20
interface Group-Async1
encapsulation ppp
no ip route-cache
ip tcp header-compression passive
no ip mroute-cache
dialer in-band
dialer hold-queue 5
dialer-group 1
async mode interactive
peer default ip address pool modem
no fair-queue
ppp callback accept
group-range 33 48
interface Dialer37
no ip address
no cdp enable
ip local pool modem 10.254.2.1 10.254.2.16
ip local pool isdn 10.254.2.20 10.254.2.30
ip classless
ip route 0.0.0.0 0.0.0.0 10.254.1.1
access-list 99 permit 10.254.1.1
access-list 110 permit ip host 10.254.1.1 host 10.254.1.2
access-list 110 permit tcp host 10.254.1.1 any eq telnet
dialer-list 1 protocol ip permit
snmp-server community public RO 99
line con 0
transport input none
line 33 48
session-timeout 600
exec-timeout 0 30
timeout login response 60
autoselect during-login
autoselect ppp
script startup reset
script reset atz
script callback cb
modem InOut
no history
transport input all
autohangup
callback forced-wait 20
stopbits 1
speed 38400
flowcontrol hardware
line aux 0
line vty 0 4
access-class 110 in
end
dbellaze
Level 4
Level 4
When you connect are you actually negotiating tcp header compression? If yes, I recall a bug that did exactly what you are experiencing.
Remove TCP compression on the Group-Async interface or turn it off on your dialup client settings and try again.
If this resolves the problem than your most likely hitting that bug. Unfortunately I do not remember the ID :(.
Daniel
Hi Daniel,
Thank you for your advice and help.
Last hours we tried different settings on our router,
and we set the following thing:
tcp header-compresson passive
compress MPPC
On the other side - Windows XP Sp2 - we set
the IP header compresson.
It works! The speed OK!!
Istvan
