871w, remote access vpn, and radius - Issue with connecting through VPN
asucrews2010
Hello, below is my VPN config in my 871 and radius user config.  I am unable to connect to the vpn using Cisco vpn client.  I am getting one of two errors depending on what config changes I make.  I believe I have the radius configured correctly because it is authencation but not 100% sure.
Error I first received, with no changes.
50     22:00:48.120  08/22/12  Sev=Warning/2    IKE/0xE3000023
No private IP address was assigned by the peer
Error I received after adding "crypto isakmp client configuration address-pool local VPN-Pool"
45     21:59:38.435  08/22/12  Sev=Warning/2    CVPND/0xE3400013
AddRoute failed to add a route with metric of 0: code 160
    Destination    172.28.29.255
    Netmask    255.255.255.255
    Gateway    192.168.17.1
    Interface    192.168.17.17
46     21:59:38.435  08/22/12  Sev=Warning/2    CM/0xA3100024
Unable to add route. Network: ac1c1dff, Netmask: ffffffff, Interface: c0a81111, Gateway: c0a81101.
Radius users config
VPN-Clients     Cleartext-Password := "cisco"
               Service-Type = "Outbound-User",
               Tunnel-Type="ESP",
               Tunnel-Password=<removed>",
                cisco-avpair = "ipsec:tunnel-type*ESP",
               cisco-avpair = "ipsec:key-exchange=ike",
               cisco-avpair = "ipsec:addr-pool=VPN-Pool",
               cisco-avpair = "ipsec:default-domain=<removed>,
                cisco-avpair = "ipsec:inacl=VPN-Split-Tunnel",
               cisco-avpair = "ipsec:dns-servers=192.168.16.10 68.105.29.12"
DEFAULT         Auth-Type := Pam
              Service-Type = Login,
               cisco-avpair = "ipsec:user-vpn-group=VPN-Clients",
VPN config on router:
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
lifetime 3600
crypto isakmp policy 2
encr aes 256
group 2
lifetime 3600
crypto isakmp key <removed> address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 900
crypto isakmp client configuration group VPN-Clients
key <removed>
dns 192.168.16.10 68.105.28.12
domain <removed>
pool VPN-Pool
acl VPN-Split-Tunnel
max-users 6
netmask 255.255.255.128
crypto isakmp profile vpn-ike-profile-1
   match identity group VPN-Clients
   client authentication list VPN-Users
   isakmp authorization list VPN-Users
   client configuration address respond
   keepalive 60 retry 30
   virtual-template 1
crypto ipsec security-association idle-time 1800
crypto ipsec transform-set encrypt-method-1 esp-aes 256 esp-sha-hmac comp-lzs
crypto ipsec profile VPN-Profile-1
set transform-set encrypt-method-1
set isakmp-profile vpn-ike-profile-1
interface Virtual-Template1 type tunnel
description VPN Zone Inside
ip unnumbered Vlan10
ip nat inside
ip virtual-reassembly
zone-member security Inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN-Profile-1
ip local pool VPN-Pool 192.168.17.1 192.168.17.17
ip access-list extended VPN-Split-Tunnel
permit ip 192.168.16.0 0.0.0.255 192.168.17.0 0.0.0.128
asucrews2010
Update:
When i remove the authenticationthrough radius, the vpn connections works.  So my issues lines with my radius config.  any idea?
asucrews2010
Update 2:
I have fixed the issue with "AddRoute failed to add a route with metric of 0" by adding the Cisco-AVPair = "isakmp-group-id=VPN-Clients"; however this leads me to a new problem were the local resources are not accessible or pingable after the vpn connection is made.  below is updated config for router and radius.  Is there something incorrect about my config that would be stopping users from accessing resources?
Router:
encr aes 256
group 2
lifetime 3600
encr aes 256
group 2
lifetime 3600
crypto isakmp key ***** address 0.0.0.0 0.0.0.0
               key *****
               dns *****
pool VPN-Pool
group-lock
               split-dns *****
max-users 6
   virtual-template 1
no crypto ipsec nat-transparency udp-encaps
ip nat inside
ip local pool VPN-Pool 192.168.17.0 192.168.17.127 group VPN-Pool
ip nat inside source list NAT interface FastEthernet4 overload
permit ip 192.168.16.0 0.0.0.255 192.168.17.0 0.0.0.255
Radius:
                Tunnel-Type="ESP",
                Tunnel-Password="*****",
                Cisco-AVPair = "isakmp-group-id=VPN-Clients",
                cisco-avpair += "ipsec:tunnel-type*ESP",
                cisco-avpair += "ipsec:key-exchange=ike",
                cisco-avpair += "ipsec:addr-pool=VPN-Pool",
                cisco-avpair += "ipsec:default-domain=*****",
                cisco-avpair += "ipsec:inacl=VPN-Split-Tunnel",
                cisco-avpair += "ipsec:dns-servers=*****",
                Framed-IP-Netmask = 255.255.255.128
                Service-Type = NAS-Prompt-User,
                Cisco-AVPair += "isakmp-group-id=VPN-Clients",
                cisco-avpair += "ipsec:user-vpn-group=VPN-Clients"
asucrews2010
Update 3, errors looked to be in the radius setup.  change service-type to outbound-users on the default user setting and everything works great.
