a problem about pix dmz and vpn
jj-zhou
Hi netpro:
I have some trouble when I config a pix515 for vpn client. the vpn client can establish with pix and it get a address from pix pool ,but the client can't ping the hosts in the dmz and pix's dmz interface.
the config :
vpn# sh run
: Saved
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
interface ethernet3 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security90
nameif ethernet3 intf3 security6
enable password xxx
passwd xxx
hostname vpn
domain-name comac.com
access-list 120 permit host 23.x.x.43
access-list 120 permit host 23.x.x.2
access-list acl_dmz permit tcp any any eq telnet
access-list acl_dmz permit icmp any any
access-list 102 permit ip 211.x.x.0 255.255.255.128 192.168.1.0 255.255.255.0
pager lines 24
logging console emergencies
logging monitor emergencies
logging buffered emergencies
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu intf3 1500
ip address outside 211.x.x.2xx 255.255.255.248
ip address inside 23.1.x.x.255.248.0
ip address dmz 211.99.71.1xx 255.255.255.128
no ip address intf3
ip verify reverse-path interface dmz
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 192.168.1.0-192.168.1.100 mask 255.255.255.0
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address dmz
no failover ip address intf3
pdm history enable
arp timeout 14400
global (outside) 1 211.99.71.2xx
nat (inside) 1 23.1.161.2 255.255.255.255 0 0
nat (inside) 1 23.1.164.67 255.255.255.255 0 0
nat (inside) 1 23.1.x.x.255.255.255 0 0
nat (dmz) 0 access-list 102
access-group acl_dmz in interface dmz
conduit permit icmp any any
route outside 0.0.0.0 0.0.x.x.99.71.254 1
route dmz 23.1.0.x.x.0.0 211.99.71.126 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
crypto ipsec transform-set comacset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set comacset
crypto map vpnmap 10 ipsec-isakmp dynamic dynmap
crypto map vpnmap client configuration address initiate
crypto map vpnmap client configuration address respond
crypto map vpnmap client authentication LOCAL
crypto map vpnmap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local vpnpool outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup mobilevpn address-pool vpnpool
vpngroup mobilevpn dns-server 23.1.160.144
vpngroup mobilevpn idle-time 900
vpngroup mobilevpn password ********
telnet 23.1.x.x.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
Vikas Saxena
No wonder you are not able to ping the dmz int from the VPN client. You do not have man dmz commnd in the PIX.
man or management-access command makes an interface accessible for the VPN client Or ipsec tunnel for telnet,snmp etc. without this the interface is never pingable because the traffic is coming from the outside.
It looks like the inside network does not have a router to 192.168.1.0/24 back to the dmz int.
You have mixed and matched the configuration of VPN client with Cisco Secure VPN client (old) with Cisco VPN 3000 Client (new). If you have downloaded the vpn client recently then it has to be Cisco VPN 3000 client.
Please clean the configuration
Sysopt pl-compatible is a dangerous command for IPSEC to be in the configuration. It is for older pix os rather newer 6.3.x it will make the natting part and ASA features of the PIX os useless for the IPSEC traffic. You do not need that.
Also you do not need
This is for older VPN clients.
The isa key * address 0 netmask 0 is also used for dynamic to static IPSEC L2L tunnels but i do not see any Dynamic L2L tunnels in the configuration as well.
Please clean the configuration.
In summary:
You would need man dmz to ping the dmz int.
You would need a route in the network for 192.168.1.0 pointing to dmz int of the pix to talk to the clients.
Always remove the passwords from the configuration before posting.
Vikas
Hi Vikas, thank your help , I resolved the probelm .
How did you solve it?
Vikas
