Hi sanderson,
You can check this documentation from the support community that explains this really good:
https://supportforums.cisco.com/document/67701/asa-versions-image-names-and-licensing
I will try running a k9 image before thinking this is a licensing issue. (you are currently running asa841-k8.bin)
Hope this info helps!!
Rate if helps you!!
-JP-
