Another ASA to Juniper site-to-site tunnel issue, lease help
mart.lubo
Hi Guys,
Some background:
- trying to establish site-to-site IPsec tunnel between ASA and Juniper (I have no access to Juniper).
- in a week of trial and error we got the tunnel established, however no trafffic is flowing, through.
- main issue prior was to get  phase 2 going. After changing proxy-id on Juniper to public IPs, instead of local IP's, phase 2 succeded.
Please have a look at running config (irrelevant outut ommited):
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
switchport access vlan 4
interface Ethernet0/4
switchport access vlan 5
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address q.q.q.q 255.255.255.0
interface Vlan2
nameif outside
security-level 0
access-list inside_nat0_outbound extended permit ip 192.168.15.0 255.255.255.0 Solon_192_Net 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.15.0 255.255.255.0 172.16.160.0 255.255.255.0
access-list split-tunnel standard permit 192.168.15.0 255.255.255.0
access-list Default_splitTunnelAcl standard permit 192.168.15.0 255.255.255.0
access-list outside_3_cryptomap extended permit ip 192.168.15.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
pager lines 24
logging enable
logging buffer-size 50000
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 172.16.160.0 255.255.255.0 x.x.x.x
route outside Solon_192_Net 255.255.255.0 x.x.x.x
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record SslVPN
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 3 match address outside_3_cryptomap
crypto map outside_map 3 set pfs
crypto map outside_map 3 set connection-type originate-only
crypto map outside_map 3 set peer y.y.y.y
crypto map outside_map 3 set transform-set ESP-AES-128-SHA
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes
hash sha
group 2
lifetime 86400
vpn-idle-timeout none
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split-tunnel
group-policy solonVPN internal
group-policy solonVPN attributes
vpn-filter value outside_3_cryptomap
vpn-tunnel-protocol IPSec svc
tunnel-group y.y.y.y type ipsec-l2l
tunnel-group y.y.y.y general-attributes
default-group-policy solonVPN
tunnel-group y.y.y.y ipsec-attributes
pre-shared-key *****
Also output of: show ipsec  sa peer  y.y.y.y
peer address: y.y.y.y
    Crypto map tag: outside_map, seq num: 3, local addr: x.x.x.x
      access-list OO_temp_outside_map3 extended permit ip host x.x.x.x host        y.y.y.y
      local ident (addr/mask/prot/port): (x.x.x.x/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (y.y.y.y/255.255.255.255/0/0)
      current_peer: y.y.y.y
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: x.x.x.x, remote crypto endpt.: y.y.y.y
      path mtu 1492, ipsec overhead 74, media mtu 1500
      current outbound spi: 2457BF99
      current inbound spi : 09A6FF7A
    inbound esp sas:
      spi: 0x09A6FF7A (161939322)
         transform: esp-aes esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, PFS Group 2, }
         slot: 0, conn_id: 24576, crypto-map: outside_map
         sa timing: remaining key lifetime (sec): 3494
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
    outbound esp sas:
      spi: 0x2457BF99 (609730457)
         IV size: 16 bytes
         Anti replay bitmap:
Any help much appreciated....
7 Replies 7
Marvin Rhoads
No encaps (or decaps) in your "show ipsec sa peer ___" output makes me wonder how the tunnel even came up in the first place. One would expect to see interesting traffic - at least in the encap entry.
You don't typically need route entries for the remote networks as you get to them via the lan to lan ipsec tunnel which sends encapsulated traffic to the peer via the default gateway.
m.kafka
Level 4
Level 4
    inbound esp sas:
         IV size: 16 bytes
         Anti replay bitmap:
    outbound esp sas:
         IV size: 16 bytes
         Anti replay bitmap:
Unfortunately you omitted some relevant parts of the config...
From what I see in the show output:
local/remote ident are the same as local/remote crypto endpoint. This will never work if you want to encrypt a traditional site-to-site VPN. local/remote ident must be the LANs on both sides. If the phase 2 negotiation between ASA and Juniper doesn't succeed post a detailed debug here.
Rgds, MiKa
Hi MiKa,
Thanks for the tip,
excuse my ignorance, I'm fairly new to ASA world, how do I change the local/remote identities, while keeping the endpoints intact?
Martin
Hi Martin,
the tunnel endpoints are defined by the tunnel group, respectively the outside IP address.
Local/remote idents are the "tunnel passengers". On the ASA these are defined by your crypto access-list, in your case "outside_3_cryptomap". The source is the local ident (your local LAN), the destination is the remote ident (the LAN behind your remote endpoint).
Hi MiKa,
my local/remote identities:
#show access-list | include outside_3
access-list outside_3_cryptomap; 2 elements; name hash: 0xb9f54e73
access-list outside_3_cryptomap line 1 extended permit ip 192.168.15.0 255.255.255.0 object-group DM_INLINE_NETWORK_1 0xedc33f46
  access-list outside_3_cryptomap line 1 extended permit ip 192.168.15.0 255.255.255.0 172.16.160.0 255.255.255.0 (hitcnt=0) 0x5ae4895a
  access-list outside_3_cryptomap line 1 extended permit ip 192.168.15.0 255.255.255.0 Solon_192_Net 255.255.255.0 (hitcnt=0) 0x9030c786
My tunnel endpoint for that VPN:
# show running-config  | include tunnel-group 206
tunnel-group 206.x.x.x. type ipsec-l2l
tunnel-group 206.x.x.x general-attributes
tunnel-group 206.x.x.x ipsec-attributes
also if i may add, initial ike phase 2 negotiation, has been failing, until  (proxy id) local and remote address has been set to public ip addresses.
in that case the juniper is misconfigured. You need to include the juniper side in the debugging process.
There is no usable case, where the local/remote ident are identical to the tunnel end points.
