Another Problem with Configuring Cisco VPN Client to Site2site VPN access
nealbrothers
We have a Cisco ASA 5505 at our CORP location, which I have configured the Site2Site VPN to our COLO with a Juniper SRX220h, the site to site works fine, but when users access the Cisco VPN client from home, they cant ping or SSH through the Site2Site.  Contacted JTAC and they said its not on their end, so I tried to contact Cisco TAC, no support.  So here I am today, after for the 3 days (including Friday last week) of searching the Internet for over 6hrs a day, and trying different examples of other users. NO LUCK. The VPN client show the secured route to 10.1.0.0
Sorry to post this but I am getting frustrated and Boss is breathing down my neck to complete this.
CORP netowrk 192.168.1.0
VPN IP pool      192.168.12.0
Colo internal ip      10.1.0.0
Also here is an example of my ASA config
: Saved
ASA Version 8.2(1)
hostname lwchsasa
names
name 10.1.0.1 colo
interface Vlan1
nameif inside
security-level 100
interface Vlan2
backup interface Vlan12
nameif outside_pri
security-level 0
ip address 64.20.30.170 255.255.255.248
interface Vlan12
nameif backup
security-level 0
ip address 173.165.159.241 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 12
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network NY
network-object 192.168.100.0 255.255.255.0
object-group service BSRO-3387 tcp
port-object eq 3387
object-group service BSRO-3388 tcp
port-object eq 3388
object-group service BSRO-3389 tcp
port-object eq 3389
object-group service OpenAtrium tcp
port-object eq 8100
object-group service Proxy tcp
port-object eq 982
object-group service VOIP10K-20K udp
port-object range 10000 20000
object-group network clientvpn
network-object 192.168.12.0 255.255.255.0
object-group service APEX-SSL tcp
description Apex Secure Dashboard Service
port-object eq 8586
object-group network CHS-Colo
network-object 10.1.0.0 255.255.255.0
object-group network DM_INLINE_NETWORK_1
network-object 192.168.1.0 255.255.255.0
network-object host 64.20.30.170
object-group service DM_INLINE_SERVICE_1
service-object ip
service-object icmp
service-object icmp traceroute
service-object tcp-udp eq www
service-object tcp eq ftp
service-object tcp eq ftp-data
service-object tcp eq sqlnet
service-object tcp eq ssh
service-object udp eq www
service-object udp eq tftp
object-group service DM_INLINE_SERVICE_2
service-object ip
service-object icmp
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object-group clientvpn
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object-group NY
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object-group CHS-Colo
access-list inside_nat0_outbound extended permit ip any 192.168.12.0 255.255.255.0
access-list outside_pri_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 object-group NY
access-list outside_pri_access_in extended permit tcp any interface outside_pri eq www
access-list outside_pri_access_in extended permit tcp any interface outside_pri eq https
access-list outside_pri_access_in extended permit tcp any interface outside_pri eq 8100
access-list outside_pri_access_in extended permit tcp any interface outside_pri eq ssh inactive
access-list outside_pri_access_in extended permit icmp any any echo-reply
access-list outside_pri_access_in extended permit icmp any any source-quench
access-list outside_pri_access_in extended permit icmp any any unreachable
access-list outside_pri_access_in extended permit icmp any any time-exceeded
access-list outside_pri_access_in extended permit tcp any 64.20.30.168 255.255.255.248 eq 8586
access-list levelwingVPN_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list levelwingVPN_splitTunnelAcl standard permit 10.1.0.0 255.255.255.0
access-list outside_pri_cryptomap extended permit ip 192.168.1.0 255.255.255.0 object-group CHS-Colo
access-list backup_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_1 192.168.12.0 255.255.255.0
access-list outside_pri_cryptomap_1 extended permit object-group DM_INLINE_SERVICE_2 192.168.1.0 255.255.255.0 10.1.0.0 255.255.255.0
access-list outside_19_cryptomap extended permit ip 192.168.12.0 255.255.255.0 10.1.0.0 255.255.255.0
access-list inside_nat0_outbound_1 extended permit ip 192.168.1.0 255.255.255.0 object-group CHS-Colo
access-list VPN-Corp-Colo extended permit object-group DM_INLINE_SERVICE_1 192.168.12.0 255.255.255.0 10.1.0.0 255.255.255.0
access-list OUTSIDE-NAT0 remark NAT0 for VPN Client to Remote Site
access-list OUTSIDE-NAT0 extended permit ip 192.168.12.0 255.255.255.0 10.1.0.0 255.255.255.0
access-list L2LVPN extended permit ip 192.168.12.0 255.255.255.0 10.1.0.0 255.255.255.0
pager lines 24
logging enable
logging buffered debugging
logging asdm warnings
logging rate-limit unlimited level 4
flow-export destination inside 192.168.1.1 2055
flow-export template timeout-rate 1
mtu inside 1500
mtu outside_pri 1500
mtu backup 1500
ip local pool LVCHSVPN 192.168.12.100-192.168.12.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 100 burst-size 5
icmp permit any inside
icmp permit any outside_pri
no asdm history enable
arp timeout 14400
nat-control
global (outside_pri) 1 interface
global (backup) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 0 access-list inside_nat0_outbound_1 outside
nat (inside) 1 0.0.0.0 0.0.0.0
nat (outside_pri) 0 access-list OUTSIDE-NAT0
nat (backup) 0 access-list backup_nat0_outbound
static (inside,outside_pri) tcp interface https 192.168.1.45 https netmask 255.255.255.255  dns
static (inside,outside_pri) tcp interface www 192.168.1.45 www netmask 255.255.255.255  dns
static (inside,outside_pri) tcp interface 8586 192.168.1.45 8586 netmask 255.255.255.255  dns
static (inside,inside) tcp interface 8100 192.168.1.45 8100 netmask 255.255.255.255  dns
access-group outside_pri_access_in in interface outside_pri
route outside_pri 0.0.0.0 0.0.0.0 64.20.30.169 1 track 1
route backup 0.0.0.0 0.0.0.0 173.165.159.246 254
timeout xlate 3:00:00
timeout conn 0:00:00 half-closed 0:30:00 udp 1:00:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 1:00:00 absolute uauth 1:00:00 inactivity
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable 981
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside_pri
http 0.0.0.0 0.0.0.0 backup
snmp-server group Authentication_Only v3 auth
snmp-server host inside 192.168.1.47 poll community lwmedia version 2c
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection tcpmss 1200
sla monitor 123
type echo protocol ipIcmpEcho 216.59.44.220 interface outside_pri
sla monitor schedule 123 life forever start-time now
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set esp-3des-sha1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ipsec df-bit clear-df outside_pri
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_pri_map 1 match address outside_pri_1_cryptomap
crypto map outside_pri_map 1 set pfs
crypto map outside_pri_map 1 set peer 50.75.217.246
crypto map outside_pri_map 1 set transform-set ESP-AES-256-MD5
crypto map outside_pri_map 2 match address outside_pri_cryptomap
crypto map outside_pri_map 2 set peer 216.59.44.220
crypto map outside_pri_map 2 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_pri_map 2 set security-association lifetime seconds 86400
crypto map outside_pri_map 3 match address outside_pri_cryptomap_1
crypto map outside_pri_map 3 set peer 216.59.44.220
crypto map outside_pri_map 3 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_pri_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_pri_map interface outside_pri
crypto isakmp identity address
crypto isakmp enable outside_pri
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash md5
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes
hash md5
group 2
lifetime 86400
track 1 rtr 123 reachability
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside_pri
dhcpd address 192.168.1.51-192.168.1.245 inside
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
dhcpd lease 86400 interface inside
dhcpd domain LM interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics host number-of-rate 2
no threat-detection statistics tcp-intercept
webvpn
port 980
enable inside
enable outside_pri
svc enable
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
group-policy GroupPolicy2 internal
group-policy GroupPolicy2 attributes
vpn-tunnel-protocol IPSec svc
group-policy levelwingVPN internal
group-policy levelwingVPN attributes
vpn-tunnel-protocol IPSec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value levelwingVPN_splitTunnelAcl
username aard password Z74.JN3DGMNlP0H2 encrypted privilege 0
username aard attributes
vpn-group-policy levelwingVPN
service-type remote-access
username rcossentino password 4UpCXRA6T2ysRRdE encrypted
username rcossentino attributes
username bcherok password evwBWqKKwrlABAUp encrypted
username bcherok attributes
username rscott password nIOnWcZCACUWjgaP encrypted privilege 0
username rscott attributes
username sryan password 47u/nJvfm6kprQDs encrypted
username sryan attributes
service-type nas-prompt
username cbruch password a8R5NwL5Cz/LFzRm encrypted privilege 0
username cbruch attributes
username apellegrino password yy2aM21dV/11h7fR encrypted
username apellegrino attributes
username rtuttle password /79ROD7fRw5C4.l5 encrypted privilege 0
username rtuttle attributes
username levelwingadmin password vJFHerTwBy8dRiyW encrypted privilege 15
username nbrothers password CAjm/rm5PYhoysB5 encrypted privilege 0
username nbrothers attributes
username clong password z.yb0Oc09oP3/mXV encrypted
username clong attributes
username finance password 9TxE6jWN/Di4eZ8w encrypted privilege 0
username finance attributes
tunnel-group DefaultL2LGroup ipsec-attributes
isakmp keepalive disable
tunnel-group 50.75.217.246 type ipsec-l2l
tunnel-group 50.75.217.246 ipsec-attributes
pre-shared-key *
tunnel-group levelwingVPN type remote-access
tunnel-group levelwingVPN general-attributes
address-pool LVCHSVPN
default-group-policy levelwingVPN
tunnel-group levelwingVPN ipsec-attributes
pre-shared-key *
tunnel-group 216.59.44.221 type ipsec-l2l
tunnel-group 216.59.44.221 ipsec-attributes
pre-shared-key *
tunnel-group 216.59.44.220 type ipsec-l2l
tunnel-group 216.59.44.220 ipsec-attributes
pre-shared-key *
policy-map global_policy
prompt hostname context
Cryptochecksum:ed7f4451c98151b759d24a7d4387935b
: end
2 Accepted Solutions
Jouni Forss
To me it seems you got most things covered.
You have however not "told" the L2L VPN configuration that traffic between the VPN Pool and the Colo network should be tunneled
access-list outside_pri_cryptomap extended permit ip 192.168.12.0 255.255.255.0 object-group CHS-Colo
Though naturally the remote end will also need the corresponding configurations for the VPN client users to be able to get traffic through to the Colo site.
- Jouni
I wouldnt recommend setting the "conn timeout" value to 0
To my understanding that means you might have several connections hanging around your ASA permanently.
- Jouni
19 Replies 19
nealbrothers
This is what I have done SO FAR
changed the COLO group policy, from GP2 to System Defualt
Changed Default L2L group keepalives to disabled
Configuration > Site-to-Site VPN > Advanced > Tunnel Groups
configured NAT rules
exempt inside CHS=Colo INBOUND
timeout conn 0:0:0
added Acces rules
192.168.12.0-imcp
added VPN-COLO-Corp to ACL manager
access-list OUTSIDE-NAT0 permit ip 192.168.12.0 255.255.255.0 10.1.0.0 255.255.255.0
nat (outside) 0 access-list OUTSIDE-NAT0
Jouni Forss
- Jouni
- Jouni
Well looks like everything is Ok with ASA, now back to JTAC, thank you for your quick support!!!!
I meant that you didnt seem to have the ACL mentioned in my post
You seemed to have the ACL line that defines that traffic from your LAN 192.168.1.0/24 would get forwarded to the remote site BUT there was no ACL rule mentioning the network 192.168.12.0/24 in the same L2L VPN crypto ACL.
- Jouni
Getting abit more confusing.
You have 2 L2L VPN configurations with the same peer IP address for the remote VPN device.
They are also supposed to tunnel traffic to the same network
Seems to me that there are some configurations that are probably not needed.
- Jouni
Ok those lines have been removed, yeah I started with company after everything was setup, so their are probably more duplicates issues like this in the config file, sorry
removing the lines below dropped the Site2Site
I didnt mean that they should be both removed.
I just stated that there are 2 almost identical L2L VPN configurations. Both connections have the same source and destination network and the same L2L VPN peer IP address. So one of them is not needed.
The key thing you were missing from the L2L VPN configuration was the ACL rule that tells the L2L VPN to tunnel the traffic from the VPN Client pool to the remote network behind the L2L VPN
If the below is the L2L VPN configuration in question
Then you needed this ACL rule in addition to the whats already configured in the ACL
This ofcourse presumes that the remote end has also made additions to their side that permits the traffic from the VPN Pool network to be tunneled to their site.
There is the command I provided before that should confirm if the L2L VPN portion is ok while you are having a continuous PING going from the VPN Client to the remote site network. (The "show crypto ipsec sa peer 216.59.44.220" command)
- Jouni
Ok well tried your command, wasn't able to ping to any of the 3 host on the 10.1.0.0/24 network
Have your VPN client connection active and have a continuous ICMP going to the remote destination IP address
Then take the output of the command
And share that here
- Jouni
Ok gonna have to try this in the Morning got meetings the rest of day! Thanks again, I keep you posted
Result of the command: "show crypto ipsec sa peer 216.59.44.220"
peer address: 216.59.44.220
    Crypto map tag: outside_pri_map, seq num: 2, local addr: 64.20.30.170
      access-list outside_pri_cryptomap permit ip 192.168.1.0 255.255.255.0 10.1.0.0 255.255.255.0
      local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (10.1.0.0/255.255.255.0/0/0)
      current_peer: 216.59.44.220
      #pkts encaps: 11653, #pkts encrypt: 11653, #pkts digest: 11653
      #pkts decaps: 17264, #pkts decrypt: 17264, #pkts verify: 17264
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 11653, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 64.20.30.170, remote crypto endpt.: 216.59.44.220
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 6A722329
    inbound esp sas:
      spi: 0x6B8AAF3A (1804250938)
         transform: esp-3des esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 8654848, crypto-map: outside_pri_map
         sa timing: remaining key lifetime (sec): 80108
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFBFDF 0xFFFFFFFF
    outbound esp sas:
      spi: 0x6A722329 (1785865001)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
Here on the Debugging results from ASA
4|Jun 05 2013|06:10:51|106023|99.174.121.14|54463|64.20.30.170|20698|Deny tcp src outside_pri:99.174.121.14/54463 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:50|106023|99.174.121.14|54463|64.20.30.170|20698|Deny tcp src outside_pri:99.174.121.14/54463 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:50|733100|||||[ Scanning] drop rate-1 exceeded. Current burst rate is 17 per second, max configured rate is 10; Current average rate is 18 per second, max configured rate is 5; Cumulative total count is 10930
4|Jun 05 2013|06:10:49|106023|99.174.121.14|54463|64.20.30.170|20698|Deny tcp src outside_pri:99.174.121.14/54463 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:48|106023|99.174.121.14|54463|64.20.30.170|20698|Deny tcp src outside_pri:99.174.121.14/54463 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:47|106023|99.174.121.14|54463|64.20.30.170|20698|Deny tcp src outside_pri:99.174.121.14/54463 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:46|106023|99.174.121.14|54463|64.20.30.170|20698|Deny tcp src outside_pri:99.174.121.14/54463 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
3|Jun 05 2013|06:10:37|713902|||||Group = 216.59.44.220, IP = 216.59.44.220, Removing peer from correlator table failed, no match!
1|Jun 05 2013|06:10:37|713900|||||Group = 216.59.44.220, IP = 216.59.44.220, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
3|Jun 05 2013|06:10:37|713902|||||Group = 216.59.44.220, IP = 216.59.44.220, QM FSM error (P2 struct &0xccc63ee8, mess id 0x124bf8bb)!
4|Jun 05 2013|06:10:30|733100|||||[ Scanning] drop rate-1 exceeded. Current burst rate is 13 per second, max configured rate is 10; Current average rate is 18 per second, max configured rate is 5; Cumulative total count is 11187
2|Jun 05 2013|06:10:29|106017|192.168.1.1||192.168.1.1||Deny IP due to Land Attack from 192.168.1.1 to 192.168.1.1
4|Jun 05 2013|06:10:19|106023|146.85.238.61|61323|64.20.30.170|20698|Deny tcp src outside_pri:146.85.238.61/61323 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:13|106023|146.85.238.61|61323|64.20.30.170|20698|Deny tcp src outside_pri:146.85.238.61/61323 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:10|106023|146.85.238.61|61323|64.20.30.170|20698|Deny tcp src outside_pri:146.85.238.61/61323 dst inside:64.20.30.170/20698 by access-group "outside_pri_access_in" [0x0, 0x0]
4|Jun 05 2013|06:10:10|733100|||||[ Scanning] drop rate-1 exceeded. Current burst rate is 14 per second, max configured rate is 10; Current average rate is 18 per second, max configured rate is 5; Cumulative total count is 11358
3|Jun 05 2013|06:10:03|713902|||||Group = 216.59.44.220, IP = 216.59.44.220, Removing peer from correlator table failed, no match!
1|Jun 05 2013|06:10:03|713900|||||Group = 216.59.44.220, IP = 216.59.44.220, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
3|Jun 05 2013|06:10:03|713902|||||Group = 216.59.44.220, IP = 216.59.44.220, QM FSM error (P2 struct &0xccc63ee8, mess id 0xa745d7b5)!
