I'm having a problem with SBL on Windows 7 (32 bit) , when trying to connect using SBL I recieve a connection faliure message almost
instantaneously.
Its not a connectivity problem as I can see the SSL handshake being attemted in the logs on the VPN head.
Once logged into the machine the client connects and prompts for credentials as expected.
To workaround this issue I have downgraded to client version 3.0.1047, is anyone else experiencing this issue with version 3.3054?
