Anyconnect ssl authentication problem on ASA 5510
Daniel.Velinov
Hello.
We have basic ASA scenario setup in a  production environment configured for SSL anyconnect and security plus license. The authentication is using Radius server on a Windows 2012 and group membership in AD group to grant access. However, when I try to connect either using the webvpn link or the installed anyconnect client I am getting Login Failed error message, but apparently the authentication was successful (see debug below).
The running config of the vpn is
ASA Version 9.1(3)
ip local pool pool1 10.150.30.1-10.150.30.250 mask 255.255.255.0
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.150.30.0_24 NETWORK_OBJ_10.150.30.0_24 no-proxy-arp route-lookup
aaa-server SAD protocol radius
aaa-server SAD (inside) host 192.168.10.15
 key *****
http server enable
crypto ca certificate chain comodo.trustpoint
ssl trust-point comodo.trustpoint outside
webvpn
 enable outside
 no anyconnect-essentials
 anyconnect image disk0:/anyconnect/anyconnect-win-3.1.04072-k9.pkg 1
 anyconnect enable
 tunnel-group-list enable
group-policy DfltGrpPolicy attributes
 dns-server value 192.168.10.8
 vpn-filter value
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-client ssl-clientless
group-policy GroupPolicy_Story-Anyconnect-VPN internal
group-policy GroupPolicy_Story-Anyconnect-VPN attributes
 wins-server none
 vpn-tunnel-protocol ssl-client ssl-clientless
tunnel-group Story-Anyconnect-VPN type remote-access
tunnel-group Story-Anyconnect-VPN general-attributes
 address-pool pool1
 authentication-server-group SAD
 default-group-policy GroupPolicy_Story-Anyconnect-VPN
tunnel-group Story-Anyconnect-VPN webvpn-attributes
 group-alias Story-Anyconnect-VPN enable
Whenever I try to login using domain account from the webvpn portal I get Login failed and the following dump
SA5510-Story-FW(config-webvpn)# webvpn_allocate_auth_struct: net_handle = 0xae330f88
webvpn_portal.c:ewaFormSubmit_webvpn_login[3628]
webvpn_portal.c:webvpn_login_validate_net_handle[2542]
webvpn_portal.c:webvpn_login_allocate_auth_struct[2562]
webvpn_portal.c:webvpn_login_assign_app_next[2580]
webvpn_portal.c:webvpn_login_cookie_check[2597]
webvpn_portal.c:webvpn_login_set_tg_buffer_from_form[2654]
webvpn_portal.c:webvpn_login_transcend_cert_auth_cookie[2688]
webvpn_login_transcend_cert_auth_cookie: tg_cookie = NULL, tg_name = Story-Anyconnect-VPN
webvpn_portal.c:webvpn_login_set_tg_cookie_form[2750]
webvpn_portal.c:webvpn_login_set_tg_cookie_querry_string[2802]
webvpn_portal.c:webvpn_login_resolve_tunnel_group[2875]
webvpn_login_resolve_tunnel_group: tgCookie = NULL
webvpn_login_resolve_tunnel_group: tunnel group name from group list
webvpn_login_resolve_tunnel_group: TG_BUFFER = Story-Anyconnect-VPN
webvpn_portal.c:webvpn_login_negotiate_client_cert[2965]
webvpn_portal.c:webvpn_login_check_cert_status[3063]
webvpn_portal.c:webvpn_login_cert_only[3111]
webvpn_portal.c:webvpn_login_primary_username[3133]
webvpn_portal.c:webvpn_login_primary_password[3212]
webvpn_portal.c:webvpn_login_secondary_username[3244]
webvpn_portal.c:webvpn_login_secondary_password[3319]
webvpn_portal.c:webvpn_login_extra_password[3431]
webvpn_portal.c:webvpn_login_set_cookie_flag[3450]
webvpn_portal.c:webvpn_login_set_auth_group_type[3473]
webvpn_login_set_auth_group_type: WEBVPN_AUTH_GROUP_TYPE = 1
webvpn_portal.c:webvpn_login_aaa_not_resuming[3551]
webvpn_portal.c:http_webvpn_kill_cookie[1053]
webvpn_auth.c:http_webvpn_pre_authentication[2087]
WebVPN: calling AAA with ewsContext (-1398866832) and nh (-1372385400)!
webvpn_add_auth_handle: auth_handle = 1985
WebVPN: started user authentication...
webvpn_auth.c:webvpn_aaa_callback[5336]
WebVPN: AAA status = (ACCEPT)
webvpn_portal.c:webvpn_login_aaa_resuming[3503]
webvpn_auth.c:http_webvpn_post_authentication[1415]
WebVPN: user: (daniel) authenticated.
webvpn_auth.c:http_webvpn_auth_accept[2794]
webvpn_session.c:http_webvpn_create_session[219]
webvpn_session.c:http_webvpn_find_session[175]
WebVPN session created!
webvpn_session.c:http_webvpn_destroy_session[1587]
webvpn_remove_auth_handle: auth_handle = 1985
webvpn_free_auth_struct: net_handle = 0xae330f88
If I go about login from the installed Anyconnect client on the PC then i get
ASA5510-Story-FW(config-webvpn)# Public archive directives retrieved from cache for index 1.
Can you please help me on that problem. Thanks
Raja Periyasamy
Enable the below debugs and connect using anyconnect vpn client and the get the debugs.
ASA5500-7# debug webvpn 255
ASA5500-7# debug radius all
Are you using DAP policies?
niemmanu
hi,
Please also share the output of show vpn-sessiondb license-summary.
Plus sh version
