ASA 1000v problem with rsa-sig authentication
andres-torres
ASA 1000v doesn't let me to select rsa-sig authentication under "crypto ikev1 policy .." when the manual says that it's possible.
ASAv-LOCAL(config-ikev1-policy)# authe
ASAv-LOCAL(config-ikev1-policy)# authentication ?
ikev1-policy mode commands/options:
  pre-share  set auth pre-share
Has anybody same problem?
Thanks in advance
BR
I attache a file with further information
AllertGen
Level 3
Level 3
Hello, .
It's just a suggestion, but maybe at your ASA hasn't been activated licence for a encryption k8/k9? Can you set a AES/3Des encryption and do you have commands to create a RSA keys?
