Hey Patrick,
I don't think you can completely disable it, but you can sure set it really high on a per-tunnel basis:
cisco(config)# crypto map rackmap 200 set security-association lifetime kilobytes ?
configure mode commands/options:
<10-2147483647> Security association duration in kilobytes (max 2,048 Gigabytes)
Keep it real bro!
James
