ASA VPN Site-to-Site (WITH NAT) ICMP problem
smarcosmarco
Hi to all!
I need to PAT traffic from 192.168.1.0/24 (through VPN) to contact remote 151.1.1.0/24, through router 192.168.123.9 in dmz (see schema)
With this configuration it works, except for ICMP.
This is the error:  Deny inbound icmp src dmz:151.1.1.1 dst outside:192.168.123.229 (type 0, code 0)
Is there a way for this?
Thanks to all!
Marco
ASA Version 8.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.1.0 remote-network
interface Vlan1
nameif inside
security-level 100
ip address 192.168.200.199 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 0
ip address 192.168.123.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
ftp mode passive
dns server-group DefaultDNS
object-group network DM_INLINE_NETWORK_1
network-object 151.1.1.0 255.255.255.0
network-object 192.168.200.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip object-group DM_INLINE_NETWORK_1 remote-network 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.200.0 255.255.255.0 remote-network 255.255.255.0
access-list VPN_NAT extended permit ip remote-network 255.255.255.0 151.1.1.0 255.255.255.0
access-list dmz_access_in extended permit icmp any any
access-list outside_access_in extended permit icmp any any
pager lines 24
logging enable
logging asdm notifications
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any dmz
asdm image disk0:/asdm-625.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (dmz) 5 192.168.123.229
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.200.0 255.255.255.0
nat (outside) 5 access-list VPN_NAT outside
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 10.0.0.100 1
route dmz 151.1.1.0 255.255.255.0 192.168.123.9 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 0.0.0.0 0.0.0.0 inside
http remote-network 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 10.0.0.1
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group 10.0.0.1 type ipsec-l2l
tunnel-group 10.0.0.1 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
JORGE RODRIGUEZ
Level 10
Level 10
Review the link,  you have two ways to allow icmp outbound , proper acl and/or icmp inspection
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
Jorge Rodriguez
