ASA5505 x2 site to site and VPN Remote on same ASA
sjcalba
Hello everyone,
Is it possible to create a site to site VPN tunnel between 2 ASA5505s and then create a Remote VPN server on one of them so that remote VPN users can connect to the LAN at the other end of the tunnel (local net access will I imagine be OK). I ask this because I have heard that you cannot do this on the ASA5505 because with the base license you can only have 1 outside interface.
Any pointers to such a configuration on the very extensive Cisco pages would be welcome. A simple corroboration or disagreement would also be very helpful.
Kind regards
sziaulla
Yes you can have both L2L and remote access on ASA. here is the sample config.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080912cfd.shtml
from license perspective you may need to check with the license team when you purchase the equipment.
thanks
-Syed
