Backup ISDN Problem
brian.oflynn
Hi, I have a very strange problem, wondering if anybody has seen this before. I have two sites connected together with a serial line and using isdn backup. The serial part is working fine. I should clarify, I am using 2 x 2600's running 12.3 IOS. I am using a floating static to bring up the ISDN. My problem is that once the line comes up the first time and drops, it won't come up anymore. The ok light on the BRI card goes out, layer 1 is deactivated and it won't come back up. The way I have made it come back up is to ring the ISDN number on both sides from my mobile phone, I get a green light again on the ok and then if I pull the serial it will come up ok. This actually happens on both sides. I done a debug and saw the following error when the line drops:
*Mar 1 23:55:42.496 UTC: ISDN BR0/0 **ERROR**: host_disconnect_ack: Unfound B-c
hannel on Disconnect_Ack call id 0x802D.
*Mar 1 23:56:04.473 UTC: ISDN BR0/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST callid 0x802D, event 0x5 ces 1
Does this mean anything to anyone? I have tried the output interpreter and found nothing.
Cheers
Brian
globalnettech
Level 5
Level 5
Hello Brian,
sounds like either an IOS bug, or an issue with yur TELCO (ISDN switches). Can you try the following:
make a conection using the 'isdn test' command, and then disconnect using the 'isdn test disconnect' command, see if that makes a difference. If you can connect after that, the issue could be with your Telco (some older ISDN switches do not properly disconnect sessions). Can you post your configs (just in case, there might be an issue) ?
GNT
Hi GNT,
Here is the relevant bits of my config:
aaa authentication ppp default local
username farside password xxxxx
isdn switch-type basic-net3
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication chap
interface Dialer1
ip address 10.10.10.5 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name Farside
dialer idle-timeout 200
dialer string XXXXXXXX
dialer load-threshold 128 either
dialer-group 1
ppp multilink
ip route 0.0.0.0 0.0.0.0 10.10.10.6 250
access-list 100 permit ip 10.1.1.32 0.0.0.31 any
dialer-list 1 protocol ip list 100
I tried the isdn test but it didn't bring up the line. I have found something new however. If I wait for 15 mins after the line has dropped and ok light has gone out, layer 1 will come up again and I can failover again no problem. It is like the Telco is not releasing the line for my use again!
Cheers
Brian
Also, the username and remote-name are actually the same case!
one thing: try and add the 'ppp multilink' to your physical interface as well:
interface BRI0/0
ppp multilink
and see if that makes a difference...
GNT
