I have a very very hard problem,Please help me!
xbw
I can connect to the PIX and the VPN client PC can receive the settings from the PIX firewall, however I am unable to see and ping the local LAN.
Network Diagram
vpn client-----(Internet)------pix---168.x.x.x
Below is the config, am I missing a route or an access-list?
All help gratefully appreciated.
: Saved
PIX Version 7.0(4)12
hostname pixfirewall
interface Ethernet0
nameif outside
security-level 0
ip address 218.87.6.77 255.255.255.192 standby 218.87.6.76
interface Ethernet1
nameif inside
security-level 100
ip address 168.50.6.150 255.255.255.0 standby 168.50.6.151
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip 168.50.6.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list outside_cryptomap_dyn_20 extended permit ip 168.50.6.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list outside_cryptomap_dyn_20 extended permit ip any 10.10.10.0 255.255.255.0
access-list Outside_access_in extended permit icmp any any
access-list splittunnel standard permit 168.50.6.0 255.255.255.0
ip local pool hpcisco 10.10.10.1-10.10.10.10 mask 255.255.255.0
failover
icmp permit any outside
icmp permit any inside
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 168.50.6.0 255.255.255.0
access-group Outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 218.87.6.65 1
group-policy hpcisco internal
group-policy hpcisco attributes
vpn-idle-timeout 20
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splittunnel
http server enable
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp nat-traversal 20
tunnel-group hpcisco type ipsec-ra
tunnel-group hpcisco general-attributes
address-pool hpcisco
default-group-policy hpcisco
tunnel-group hpcisco ipsec-attributes
pre-shared-key *
Cryptochecksum:xxx
: end
sebastan_bach
Level 4
Level 4
hi there i can solve ur problem.u have not assigned the
vpn-address-assign local
this command is required to tell that the vpn clients will be assigned addresess locally. plus pls check in ur policy map with the command
sh run policy-map global_policy
whether u have enabled inspection for icmp.
pls also check with this command
sh sysopt
it should show u
sysopt connection permit-ipsec
thsi has to be there for avoiding the crypto acl check on the outside for the vpn clients .
tell whether this has helped u . waiting for ur reply.
regards
sebastan
1、 I haven't enabled inspection for icmp
Result of the command: "sh run policy-map global_policy"
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
2、Result of the command: "show run syso"
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
no sysopt uauth allow-http-cache
3、I don't understand vpn-address-assign local
Result of the command: "show running-config all vpn-addr-assign"
vpn-addr-assign aaa
vpn-addr-assign dhcp
vpn-addr-assign local
Can you still help me,thanks.
You've probably solved this already by now, but version 7 needs an access list permiting inside traffic out.
eaccess-list inside_out permit ip any any
access-group inside_out in interface inside
Cheers Tony
