Call connection timeout isdn
m.paolelli
Hi all.
I've got a ROUTER 2651XM with an IOS Version 12.3(8)T3, and a Voice Card for 2 ISDN BRI.
The voice gateway is connected, at the other side, to a CallManager.
I'd like to terminate ANY CALLS after 15 minutes of conversation...
How and Where can I set this timeout?
b.speltz
Level 4
Level 4
Resolve this issue by adjusting the timeout on the gateway for the ISDN t310 timer.
Set the timer to a high value, such as 60000. This value makes the timeout 60 seconds which should be long enough for any network. The timer is found under the serial interface configuration on a Cisco AS5300, 2600, 3600, 3700
