Cisco 2611xm and NM-32a module - HELP
network27
I have a question I'm not sure if it difficult or not. I have a NM-32a in
my 2611xm using IOS version: 2600-jk9s-mz.123-24.b. The problem is that I cannot setup the 2611xm to connect to my other cisco devices. I have read Cisco's Configuring a Terminal / Comm server (Doc ID:5466) and it has not helped me I still can't connect any of the devices. Any idea?
Access-Server(config)#do sh run
version 12.3
hostname Access-Server
boot-start-marker
boot-end-marker
enable secret xxx
memory-size iomem 10
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip host Router1 2033 172.21.1.1
ip host Router2 2034 172.21.1.1
ip host Router3 2035 172.21.1.1
ip host Router4 2035 172.21.1.1
ip host Router5 2036 172.21.1.1
username cisco password 0 cisco
interface Loopback1
ip address 172.21.1.1 255.255.255.0
interface FastEthernet0/0
ip address 139.x.x.50 255.255.255.0
duplex auto
speed auto
line con 0
line 33 64
transport input telnet
flowcontrol hardware
line aux 0
line vty 0 4
password cisco
login
Access-Server#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 2 0 0/0 -
* 33 TTY 9600/9600 - - - - - 0 48 52/158 -
* 34 TTY 9600/9600 - - - - - 1 25 53/164 -
* 35 TTY 9600/9600 - - - - - 0 88 8/26 -
* 36 TTY 9600/9600 - - - - - 0 13 17/54 -
* 37 TTY 9600/9600 - - - - - 1 0 0/0 -
38 TTY 9600/9600 - - - - - 2 0 0/0 -
39 TTY 9600/9600 - - - - - 0 11 12/37 -
40 TTY 9600/9600 - - - - - 0 11 19/59 -
41 TTY 9600/9600 - - - - - 0 17 27/82 -
42 TTY 9600/9600 - - - - - 0 37 36/110 -
43 TTY 9600/9600 - - - - - 0 0 0/0 -
44 TTY 9600/9600 - - - - - 0 23 0/0 -
45 TTY 9600/9600 - - - - - 0 0 0/0 -
46 TTY 9600/9600 - - - - - 0 0 0/0 -
47 TTY 9600/9600 - - - - - 0 27 0/0 -
48 TTY 9600/9600 - - - - - 0 0 0/0 -
49 TTY 9600/9600 - - - - - 0 11 0/0 -
50 TTY 9600/9600 - - - - - 0 1 0/3 -
51 TTY 9600/9600 - - - - - 0 0 0/0 -
52 TTY 9600/9600 - - - - - 0 0 0/0 -
53 TTY 9600/9600 - - - - - 0 0 0/0 -
54 TTY 9600/9600 - - - - - 0 0 0/0 -
lgijssel
Level 9
Level 9
Still you seem to have missed a few settings. the following must be in the config:
line 33 64
transport preferred telnet
transport input all
Please post a "sh line" for one of the lines on the NM32A.
regards,
Leo
thanks lgijssel,
it works.
However, I cant ssh to the router remotely. Please advise
