Cisco 7140 IPSec problem
leung_wilson
My 7120 kis getting cert and operating well with Entrust CA and Injoin. I have problems with 7140. I have the exact same setup and IOS (12.2) for both. When I ran show cry eng conf on 7120 I got the following:
crypto engine name: Unknown
crypto engine type: hardware
Cryptic verion: OxFF41
CGX version: 0x0111
DSP firmware version: 0x0065
MIPS firware version: 0X030362700
ISA/ISM Serial number:6BA........
PCDB info: 3-DES [.....]
Compression: NO
3 DES: Yes
Maximum buffer lenght: 4096
Maximum DH index: 1014
Maximum SA index: 2029
Maximum Flow index: 4059
Maximum RSA Key Size: 2048
Crypto engine in slot: 5
platform: predator crypto-engine
Crypto Adjacency Counts:
Lock Count: 9988
But when I ran the same command on 7140, I got the following instead:
Lock Count: 0
Unlock Count: 0
My 7140 does not communicate with other routers via Entrust CA. Is the 7140 hardware broken?
Thanks in advance.
W
r-simpson
Level 3
Level 3
'show crypto isakmp sa' and 'show crypto ipsec sa' are the preferred methods for monitoring/checking IPSEC tunnels. I would suggest trying those commands on your 7140 to see if you get the same results.
