08-16-2011 08:51 AM
I bought a new Cisco 861 ISR with advanced security license on it.
When I look into the license Dashboad in Cisco Configuration Professional it tells me that I have advsecurity License Feature with Deployment Status "Deployed" and State "Active, in use".
But when I want to configure any type of VPN i get the following error message:
Technology license (advsecurity) associated with this feature is not deployed on this router. Use the link below to deploy the technology license.
When I click the link I end up in the License Dashboard again.
I don´t have another license file and advanced security Feature set should be sufficient for VPNs. At least that is what
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_461543.html tells me.
What do I have to do to be able to configure the VPN ?
Thankx a lot for any help
Dirk
Solved! Go to Solution.
08-16-2011 01:32 PM
What version of CCP are you using? I see a few other customer cases with this error and it looks like there may be an issue with CCP 2.5. Customers using CCP 2.3 do not see this error when applying the license via the GUI.
Todd
08-16-2011 01:32 PM
Todd
08-17-2011 01:25 AM
Hello Todd,
thankx for the heads up on the CCP Version. Indeed I was using CCP 2.5 and had the Problem with the licensing.After switching tp CCP 2.3 the Problem was gone and I was able to configure the VPN Connection as needed.
Dirk
