Cisco 877W comms problem
athol
Hi I have been struggling with a configuration problem for some time, and I am sure that I missing something simple, but at the moment is it beyond me. The issue is this. I have been given a Cisco 877W ADSL wireless router to use at home. I have the ADSL stuff working and I have the wireless half working. The position of the router is that it is sitting between the internet and a linux firewall/webserver, a l2 managed switch (Intel 460) 24 port switch which has 2 vlans on it one the default and the other running dot1q back to F2 on the router. What I am attempting to do is have my sons friends connect via the wireless interface and have the data travel back through the vlan to the firewall where I am running smnp and traffic shapping. From the inside of the network I can ping everything this includes the wireless attached laptops. my problem is that using the laptop connected to the wireless interface I can ping it'self, the dhcp gateway and the IP of the dialer0 interface I am not able to ping anything else. dot1q is enabled and the vlan is linked back to the dotradio 0.2 sub interface. I am currently using trunking on the router although I have also tried to bridging the interface as well. I can ping directly from the router through to hte switch and I have also unplugged the cable upon which vlan2 travels. This action causes ping to fail so I beleive that the vlan is ok, howerver I have not had any success at all up to this point. Can anyone out there help me please ?
Thank you
Athol Reid
27 Replies 27
Hello Athol,
can you make a drawing of your physical setup and post it ?
GP
Hi Georg
I have attached a jpg of my home network infrastrucure
Cheers
Hello Athol,
thanks for the drawing, that clarifies what you are running into.
You say that the wireless laptop can ping the dialer 0 interface of the 877, can you tell if the address actually gets translated when you ping something on the Internet from the wireless laptop ?
I think in order for traffic from the wireless laptop to travel through the 877 to the switch and then the firewall and then back, you would need to establish some sort of policy routing. Traffic from the wirless laptop needs to be matched and the next hop needs to be the inside IP address of the firewall (172.16.100.4, as far as I can tell from your drawing). So on your 877, the route map should look like this:
route-map WIRELESS permit 10
match ip address 1
set ip next-hop 172.16.100.4
access-list 1 permit 10.10.10.0 0.0.0.255
Apply the route map to the incoming (DOT1) interface of the 877, that is the interface where the wirless laptop is connected to, with the ´ip policy route-map WIRELESS´ command.
Assuming that your firewall has a route back to the 877, the traffic should now first go to the firewall, and then back to the 877...
Can you try and see if this works ?
GP
Hi Georg
Thank you for the pointer, I have tried it to-day and I can now get out onto the internet from the wireless (DOT1) interface. The Vlan is not yet working as I cannot ping from the router at the moment. This is just "finger trouble" on my part I am sure. Your conf has worked a treat!!!
Thank you very much
Athol Reid
Hello Athol,
good to hear that you are making progress...
Where are you trying to ping to from the router ?
Keep in mind that, when you use the ´ping´ command on the router, the default source for the ping is the interface closest to the destination. You might want to try an extended ping, just type ´ping´ and hit , that will give you configurable options...
GP
Hi Georg
I am trying from two different palaces. from a client through the wireless interface and from the router itself. If I do not Vlan the intel switch I can ping it from the router only, (bearing in mind that I was never able to ping from the wireless client). If on the other hand I vlan the switch with 802.1q encapsulation and also on the dotradio0.2 plus the vlan 2 interface on the router then I can not ping it. In writing this down it is begining to suggest a route issue ?
Kind Regards
Athol Reid
Hi Georg
I have been experimenting with the policy maps and routing, the situation that I am currently in is the same as before in that from the Windows XP Pro client ip 10.10.10.51 I can ping the gateway on 10.10.10.1 and I can also resolve web IP addresses but I can not ping 172.16.100.x devices. I have posted my conf in an attempt to be helpful and I would appreciate it if you could have a look and comment please.
version 12.4
no service pad
service password-encryption
hostname ADSLW-ROUTER
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
no aaa new-model
resource policy
clock timezone PCTime 12
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.49
ip dhcp excluded-address 10.10.10.100 10.10.10.254
ip dhcp pool wireless-1
import all
network 10.10.10.0 255.255.255.0
domain-name reid.co.nz
dns-server 203.109.252.42 203.109.252.42
default-router 10.10.10.1
no ip bootp server
no ip domain lookup
ip domain name reid.co.nz
ip name-server 203.109.252.43
ip name-server 203.109.252.42
ip ssh time-out 60
ip ssh authentication-retries 2
ip ddns update method sdm_ddns1
DDNS both
no spanning-tree vlan 1
no spanning-tree vlan 2
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet2
switchport mode trunk
interface Dot11Radio0
no ip address
ssid ADSLW-1
vlan 2
authentication open
guest-mode
interface Dot11Radio0.2
encapsulation dot1Q 2
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no snmp trap link-status
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_OUTSIDE$
ip address 192.168.100.254 255.255.255.0
ip verify unicast reverse-path
ip nat inside
interface Vlan2
description $FW_INSIDE$
ip address 172.16.11.14 255.255.255.0
ip nat inside
fair-queue 2 256 0
interface Dialer0
ip ddns update sdm_ddns1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname USERID
ppp chap password 7 PASSWORD
ppp pap sent-username USERID password
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
no cdp run
route-map dotradio0.2 permit 10
match ip address 1
control-plane
end
Kind Regards
Athol Reid
Hello Athol,
from what I can tell from your configuration, you would need to apply the route map to your Dot11Radio0.2 and VLAN1 interfaces:
ip nat inside
no cdp enable
--> ip policy route-map dotradio0.2
interface Vlan1
ip nat inside
Can you try this and see if that makes a difference ?
GP
Hi Georg
I have put the commands in but they have not had the desired effect yet. I did a sh vlans dot1q and the results are below
ADSLW-ROUTER#sh vlans dot1q
Total statistics for 802.1Q VLAN 1:
0 packets, 0 bytes input
0 packets, 0 bytes output
Total statistics for 802.1Q VLAN 2:
7865 packets, 853292 bytes input
11718 packets, 14695364 bytes output
Kind Regards
Athol Reid
Hello Athol,
I hope that I am not just adding to the confusion, but your VLAN 1 interface has an IP address of 192.168.100.254, and the inside interface of your firewall, which is in VLAN 1 as well, has an IP address of 172.16.100.4. If you have an IP address available form the 172.16.100.0/24 range, can you try and put it on the VLAN 1 interface of your router as a secondary address ?
interface Vlan1
--> ip address 172.16.100.1 255.255.255.0 secondary
ip nat inside
GP
Hi Georg
I have done as you suggested but it stopped all comms at the 192.168.100.254 interface. I added an access-list of 192.168.100.0 0.0.0.255 and tried again but to no avail. I removed the entries in the meantime so that I could respond.
Kind Regards
Athol Reid
all right...I think I made a mistake in the first place by adding the 192.168.100.0/24 subnet to the route map. Can you take this out of access list 1, and also take the route map off interface VLAN 1 ? So your config would look like this:
version 12.4
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
no ip source-route
ip cef
import all
no ip bootp server
no ip domain lookup
ip ssh time-out 60
DDNS both
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/100
no ip address
ssid ADSLW-1
vlan 2
authentication open
guest-mode
ip nat inside
-->ip policy route-map dotradio0.2
no cdp enable
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
fair-queue 2 256 0
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip classless
ip http server
no cdp run
match ip address 1
control-plane
end
GP
Hi Georg
Thank you for that. I removed everything back to the last conf you uploaded. once this was done and I tried to ping the DNS server I was not able to get through from any network. I added another access-list to allow coms to the outside world and I have listed it below.
access-list 2 remark SDM_ACL Category=2
access-list 2 remark From Vlan1 to outside
access-list 2 permit any
no cdp run
match ip address 1
I guess I am confused about the routing and also if Tagging is actually working, as I said before I pulled the cable that directly connects the router to the switch on port 6 and data flow stopped. Now I am just confused as to how that actually worked in the first place or was I mistaken and it never worked.???
Georg I appreciate your advice and any scraps you wish to throw my way are gratefully received and hopefully assimulated.
Kind Regards
Athol Reid
Hello Athol,
I will try to set this up in a lab and see if I can make it work. I'll let you know...
Due to the time difference (it is about 11PM over here, you might get this tomorrow).
GP
