Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco anyconnect instaling problem
jhon.kingsman69
hi guys have you having a wonderful day, I was going to install cisco anyconnect but I get the error
There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor
I also tried to uninstall and install again but I found out there is 2 reg file that cant be removed whatsoever in my PC i attached the picture of these 2 files, any idea how can i fix it?
   - You may want to re-install Windows 10 completely (save user data) and try again.
 M.
marce1000
      - Which version of Windows are you using ?
 M.
I'm using windows 10
 M.
