Cisco ASA 5505 Ipsec VPN and random connection dropping issues.
Belnetsolutions
We are currently having issues with a ASA 5505 Ipsec VPN. It was configured about 7-8 months ago and has been running very well..up until the last few weeks.  For some reason, the VPN tends to randomly disconnect any user clients connected a lot.  Furthermore, sometimes it actually connects; however does not put us on the local network for some reason and unable to browse file server.  We have tried rebooting the ASA a few times and our ISP Time Warner informed us there are no signs of packet loss but still unable to pinpoint the problem.  Sometimes users close out of VPN client completely, reopen several times and then it works.  However it's never really consistent enough and hasn't been the last few weeks.  No configuration changes have been made to ASA at all.  Furthermore, the Cisco Ipsec VPN client version is: 5.0.70
Directly below is our current running config (modded for public).  Any help or ideas would be greatly appreciated.  Otherwise, if everything looks good...then I will defer back to our ISP Time Warner:
: Saved
ASA Version 8.4(2)
hostname domainasa
domain-name adomain.local
enable password cTfsR84pqF5Xohw. encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 205.101.1.240 255.255.255.248
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 192.168.2.60
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network SBS_2011
host 192.168.2.60
object network NETWORK_OBJ_192.168.2.0_24
subnet 192.168.2.0 255.255.255.0
object network NETWORK_OBJ_192.168.5.192_
27
subnet 192.168.5.192 255.255.255.224
object network Https_Access
host 192.168.2.90
description Spam Hero
object-group network DM_INLINE_NETWORK_1
network-object object SPAM1
network-object object SPAM2
network-object object SPAM3
network-object object SPAM4
network-object object SPAM5
network-object object SPAM6
network-object object SPAM7
network-object object SPAM8
object-group service RDP tcp
description Microsoft RDP
port-object eq 3389
access-list outside_access_in extended permit tcp object-group DM_INLINE_NETWORK_1 object SBS_2011 eq smtp
access-list outside_access_in extended permit tcp any object SBS_2011 eq https
access-list outside_access_in extended permit icmp any interface outside
access-list outside_access_in remark External RDP Access
access-list outside_access_in extended permit tcp any object SBS_2011 object-group RDP
access-list domain_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool test 192.168.10.1-192.168.10.5 mask 255.255.255.0
ip local pool VPN_Users 192.168.5.194-192.168.5.22
0 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.2.0_24
destination static NETWORK_OBJ_192.168.5.192_
27 NETWORK_OBJ_192.168.5.192_
27 no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp smtp smtp
nat (inside,outside) static interface service tcp https https
nat (inside,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 205.101.1.239 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-reco
rd DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.2.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.2.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.2.160-192.168.2.19
9 inside
dhcpd dns 192.168.2.60 24.29.99.36 interface inside
dhcpd wins 192.168.2.60 24.29.99.36 interface inside
dhcpd domain adomain interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy domain internal
group-policy domain attributes
wins-server value 192.168.2.60
dns-server value 192.168.2.60
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value domain_splitTunnelAcl
default-domain value adomain.local
username ben password zWCAaitV3CB.GA87 encrypted privilege 0
username ben attributes
vpn-group-policy domain
username sdomain password FATqd4I1ZoqyQ/MN encrypted
username sdomain attributes
username adomain password V5.hvhZU4S8NwGg/ encrypted
username adomain attributes
service-type admin
username jdomain password uODal3Mlensb8d.t encrypted privilege 0
username jdomain attributes
service-type admin
tunnel-group domain type remote-access
tunnel-group domain general-attributes
address-pool VPN_Users
default-group-policy domain
tunnel-group domain ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:e2466a5b754
eebcdb0cef
f051bef91d
9
: end
Thanks again
Julio Carvajal
Hello Belnet,
What do the logs show from the ASA.
Can you post them ??
Any other question..Sure..Just remember to rate all of the community answers.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
