Cisco ASA - Use Path Monitoring for VPN Failover?
dervari
Does the ASA have a mechanism by which we can monitor a VPN tunnel using an SLA/Track to a private IP on the remote side and if the SLA fails, re-reroute traffic via a second VPN configured to a different peer?  A partner has this type of configuration set up on a Palo Alto where they are pinging a device on our LAN and if they miss pings to it the VPN fails over to a separate physical box on a different WAN IP.
The problem we are having is that their routes fail over but we don't.  We have a secondary peer configured and our side will not fail over to the secondary peer unless the IPSec connection to the primary fails, which it doesn't.
Thanks.
So are you saying that the IPSec tunnel is still established even though the other end is down? In which case ensure Dead Peer Detection (DPD) is configured, guide here. This will clear the IPSec SA if the remote peer is down, therefore you secondary peer should then establish a tunnel
