07-27-2010 08:53 PM
We are running Cisco VPN client 5.0.07. When we connect to the internet by using the Verizon Broadband wireless card, the VPN client would disconnect after 2 minutes with split-tunnel. However, if we setup full tunnel, the VPN client would not disconnect. Have you run into this problem before? Do you have any suggestions?
Thanks.
Laura
07-28-2010 05:03 PM
Can you post the VPN client logs when it gets disconnected?
07-29-2010 09:42 AM
07-29-2010 05:23 PM
hi I see the vpn client terminating the connection by sending a delete to the headend. But not sure what the trigger is as it is very general in the logs. So you are facing the same issue for all versions of vpn client or only the 5.07?Can u post the gist of vpn config on the headend?
07-29-2010 05:46 PM
Thanks for your prompt response, Rahgovin. I am running VPN 3005 Concentrator and do not know how to copy the config.
Thanks.
Laura
