CiscoSecure VPN Client 1.1 with PIX problems routing
jasonhumes
Hello
I've got a cisco Secure VPN Client1.1 trying to connect to a pix via IPSec. Basically this is an existing config which I'm trying to optimize. There are two internal networks on the inside of the pix. Is there any way to set up the VPN Client 1.1 to be able to use both internal networks through the VPN tunnel? How is this routing performed? Thanks...Could someone direct me to some docs on this client. Thanks again.
nikhil_m
Hi there,
I think you can do it according to this document:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csvpnc/csvpnsg/icover.htm
best wishes,
Nikhil
