Connection issues with Anyconnect Mobility v3.03050 and IOS (151-2.T4)
biraja
Hi Guys,
On my setup SSLVPN tunnel fails with AnyConnect 3.0.3050 or above releases to UC520 platform running IOS(151-2.T4).
3.0.4235
3.0.3054
3.0.3050
Connection succeeds with all other versions below 3.0.3050.
I’m using standalone client on my PC (tried Win7 and XP).
I added my server to the trusted sites list on my IE.
When I tried with anyconnect-win-3.0.3050-k9.pkg which was installed on UC520, the client gets installed successfully and connection was established.
When I disconnect the session (had an option to keep the client on PC) and tried to connect back, the connection failed after I have accepted the certificate.
I don't see any webvpn debugs on the UC520.
Any help is appreciated.
Biraja
biraja
My WebVPN config:
UC_520#sh runn | b webvpn
webvpn gateway SDM_WEBVPN_GATEWAY_1
ip address 171.71.232.88 port 443
ssl trustpoint TP-self-signed-995375956
inservice
webvpn install svc flash:/webvpn/anyconnect-win-3.0.3050-k9.pkg sequence 1
webvpn context SDM_WEBVPN_CONTEXT_1
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group SDM_WEBVPN_POLICY_1
   functions svc-enabled
   svc address-pool "SDM_WEBVPN_POOL_1"
   svc keep-client-installed
   svc dtls
virtual-template 1
default-group-policy SDM_WEBVPN_POLICY_1
aaa authentication list sdm_vpn_xauth_ml_1
max-users 20
inservice
end
