%CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet
mahesh18
Level 6
Level 6
Hi Everyone,
I have GRE over IPSEC  tunnel between 2691 and 3550.
2691 connects to Internet and do the Natting.
Tunnel seems to be up up and working fine but on 2691 i am seeing these in logs
Dec 23 10:07:27.580 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 23 10:08:05.957 MST: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: mintoo] [Source: 192.168.5.2] [localport: 23] at 10:08:05 MST Sun Dec 23 2012
Dec 23 10:08:27.582 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 23 10:09:27.585 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
2691Router#                          sh crypto isakmp sa
dst             src             state          conn-id slot status
192.168.5.2     192.168.5.3     QM_IDLE             38    0 ACTIVE
2691Router# sh cry
2691Router# sh crypto ipsec sa
interface: FastEthernet0/1
    Crypto map tag: MYVPN, local addr 192.168.5.3
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.5.3/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (192.168.5.2/255.255.255.255/47/0)
   current_peer 192.168.5.2 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 3646, #pkts encrypt: 3646, #pkts digest: 3646
    #pkts decaps: 4, #pkts decrypt: 4, #pkts verify: 4
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 1, #recv errors 0
     local crypto endpt.: 192.168.5.3, remote crypto endpt.: 192.168.5.2
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/1
     current outbound spi: 0x28553A1D(676674077)
     inbound esp sas:
      spi: 0x2BD49D31(735354161)
        transform: esp-des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 2002, flow_id: AIM-VPN/EPII:2, crypto map: MYVPN
        sa timing: remaining key lifetime (k/sec): (4449766/1872)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2001, flow_id: AIM-VPN/EPII:1, crypto map: MYVPN
        sa timing: remaining key lifetime (k/sec): (4449739/1872)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
How can i fix the log on 2691 router .
Also how can i tell which side is doing encryption and which not ?
Many thanks
MAhesh
28 Replies 28
olpeleri
That means the remote device is bypassing encryption and sends GRE in clear. Can you show the configs of the device with the IP 192.168.5.3?
Cheers,
Hi olpeleri,
Thanks for reply
here is config of device with 192.168.5.3
Current configuration : 9257 bytes
! Last configuration change at 14:33:15 MST Sun Dec 23 2012 by mintoo
! NVRAM config last updated at 14:18:18 MST Sun Dec 23 2012 by mintoo
version 12.4
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
hostname 2691Router
boot-start-marker
boot-end-marker
no logging exception
logging count
logging buffered 4096 informational
enable secret level 5 5 $1$EC0J$upgsksyfc5JJ/ree2A9BO0
enable secret 5 $1$Z9E.$rWrUh71AcmeDMxFDsrZVl0
no aaa new-model
clock timezone MST -7
clock summer-time MST recurring
no network-clock-participate slot 1
no ip icmp rate-limit unreachable
ip cef
ip host 3550SMIA 192.168.5.2
ip host 3550SMIB 192.168.10.2
ip host 2950T 192.168.10.5
ip host 2650XM 192.168.4.3
ip name-server 64.59.144.18
ip auth-proxy max-nodata-conns 3
login on-failure log
login on-success log
ipv6 unicast-routing
archive
log config
  hidekeys
path slot0:/configs/$h
write-memory
time-period 1440
ip ssh port 2009 rotary 1
crypto isakmp policy 100
encr aes
authentication pre-share
group 2
crypto isakmp key cagary address 192.168.5.2 no-xauth
crypto ipsec transform-set DEMO1 esp-des esp-sha-hmac
crypto map MYVPN 100 ipsec-isakmp
set peer 192.168.5.2
set transform-set DEMO1
match address MP
buffers tune automatic
interface Loopback2
description IBGP neighbour to Router 3550B
ip address 2.2.2.2 255.255.255.0
interface Loopback3
description IBGP neighbour to Router R4
ip address 3.3.3.3 255.255.255.0
interface Loopback4
ip address 4.4.4.4 255.255.255.0
interface Loopback33
description IPV6 OSPF LAB
no ip address
ipv6 address FEC0:4::4/64
ipv6 enable
ipv6 ospf 110 area 100
interface Loopback133
no ip address
ipv6 address FEC0:1::1/64
ipv6 enable
ipv6 ospf 100 area 101
interface Tunnel0
ip address 10.5.1.2 255.0.0.0
tunnel source FastEthernet0/1
tunnel destination 192.168.5.2
interface FastEthernet0/0
description WAN Connection to ISP modem
ip address dhcp
no ip redirects
no ip unreachables
ip accounting output-packets
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
description Serial connection to 2650 on interface se/0/0
encapsulation frame-relay
ip ospf network point-to-multipoint
no keepalive
interface FastEthernet0/1
description Lan Connection to 3550A Switch
ip address 192.168.5.3 255.255.255.254
ip flow ingress
ip nat inside
ip ospf hello-interval 40
ip ospf priority 10
duplex auto
speed auto
crypto map MYVPN
interface FastEthernet1/0
description Lan Connection to 3550B Switch
ip address 192.168.6.3 255.255.255.254
ip flow ingress
ip nat inside
ip ospf authentication
ip ospf authentication-key 7 05080F1C2243
ip ospf priority 10
duplex auto
speed auto
interface Serial1/0
description Serial connection to 2650 on interface se0/1
ip address 192.168.2.1 255.255.255.0
no keepalive
serial restart-delay 0
interface FastEthernet1/1
router ospf 1
router-id 4.4.4.4
log-adjacency-changes
redistribute static metric 300 subnets
passive-interface Serial0/0
passive-interface Serial1/1
network 3.3.3.3 0.0.0.0 area 0
network 4.4.4.4 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 192.168.5.0 0.0.0.255 area 0
network 192.168.6.0 0.0.0.255 area 0
default-information originate
ip nat translation timeout 3600
ip nat inside source list 101 interface FastEthernet0/0 overload
ip access-list extended MP
permit gre host 192.168.5.3 host 192.168.5.2 log
logging trap debugging
logging 192.168.20.9
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
hope this helps
thanks
mahesh
Probably the problem has something to do with different config of  proxy-ACL on peers. Maybe it'll help if you simplify crypto-acl on both peers this way:  access-list 101 permit gre any any
Hi Andrew.
Can you please let me know how can i do different config of proxy ACL on peers?
thanks
mahesh
This side looks good. How the other side looks like?
Hi olpeleri,
Here is config from other side
encr aes
group 2
crypto isakmp key cagary address 192.168.5.3 no-xauth
set peer 192.168.5.3
match address MP
interface Tunnel0
ip address 10.5.1.1 255.0.0.0
tunnel source FastEthernet0/11
tunnel destination 192.168.5.3
interface FastEthernet0/11
description OSPF LAN Connection to 2691 Router
no switchport
ip address 192.168.5.2 255.255.255.254
crypto map MYVPN
router ospf 1
router-id 3.4.4.4
area 10 virtual-link 10.4.4.1
passive-interface Vlan10
passive-interface Vlan20
network 3.4.4.4 0.0.0.0 area 0
network 10.0.0.0 0.255.255.255 area 0
network 192.168.4.0 0.0.0.255 area 10
network 192.168.10.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 192.168.98.0 0.0.0.255 area 0
network 192.168.99.0 0.0.0.255 area 0
permit gre host 192.168.5.2 host 192.168.5.3 log
this is th eother side.
thanks
mahesh
It's all right with proxy acl, i didn't pay anough attention to config you provided first time). To me config on both sites seems  fine. How often do u see those logs?
Hi Andrew,
Every one min on 2691 router.
Dec 24 10:09:28.358 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:10:28.360 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:11:28.363 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:12:28.366 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:13:38.365 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:14:38.367 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:15:38.369 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:16:38.372 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:17:48.371 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:18:48.373 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:19:48.376 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:20:48.378 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:21:58.377 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:22:58.380 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 24 10:23:58.382 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
2691Router#
Also when i enable IPSEc  between two tunnels my ospf nei for tunnel goes down is this normal behaviour?
Mahesh
In order to make your ospf ajacency active when secure tunnel is up u have to
on 2691:
delete this statements from ospf config:
-network 192.168.5.0 0.0.0.255 area 0, which refers to real interfaces IPs
and replace them with
-network 10.0.0.0 0.255.255.255 area 0, wich refers to tunnel interfaces IPs.
on 3550:
-just delete 192.168.5.0 0.0.0.255 area 0
from ospf config.
OSPF adj should be made between tunnel ip addresses.
Hi Andrew,
I did as you said what after doing that
2691 has no ospf nei adj to 3550
On 3550 when i do sh ip route it does not show any ospf routes.
IT has static route only.
MAhesh
Message was edited by: mahesh parmar
Hi Andrew,
I tried number of times to make OSPF adj with Tunnel interfaces but no luck.
Mahesh
If you did what i said in the previos post, to me your config seems fine. But, probably, i'm missing something)) Try it without ipsec. Just GRE. And see what will happen. Plus, about IPSec, it's better practice to use VTI interfaces then just regular GRE over IPSec.
So, for now, just try it without securing your tunnel (remove crypto map statements from interfaces configs).
Rudy Sanjoko
Level 4
Level 4
the reason you get that message because the tunnel is not protected, it's true that the GRE tunnel was established but it is not protected, you can create an ipsec profile then apply the transform set to that profile, after that you can apply the ipsec profile to the tunnel using the tunnel protection command,
R1(config)# crypto ipsec transform-set TRANS-SET esp-3des esp-md5-hmac
R1(cfg-crypto-trans)# mode transport
R1(config)# crypto ipsec profile ipsec-prof
R1(ipsec-profile)# set transform-set TRANS-SET
R1(config)# interface Tunnel 0
R1(config-if)# tunnel protection ipsec profile ipsec-prof
By applying above commands, you will have a GRE over IPSEC, not just plain GRE tunnel and that should get rid of the error message you are having or you can apply the crypto map to the tunnel interface as well.
rudy.sanjoko, you're not correct. His gre tunnel was protected, but using regular crypto-maps (old way). What you suggest is just another implementation of it (new way) but it does the same thing.
To what u suggest i'd add also tunnel mode ipsec ipv4 to reduse overhead.
