Showing results forĀ
Search instead forĀ
Did you mean:Ā
%CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet
mahesh18
Level 6
Level 6
Hi Everyone,
I have GRE over IPSEC  tunnel between 2691 and 3550.
2691 connects to Internet and do the Natting.
Tunnel seems to be up up and working fine but on 2691 i am seeing these in logs
Dec 23 10:07:27.580 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 23 10:08:05.957 MST: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: mintoo] [Source: 192.168.5.2] [localport: 23] at 10:08:05 MST Sun Dec 23 2012
Dec 23 10:08:27.582 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
Dec 23 10:09:27.585 MST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /192.168.5.3, src_addr= 192.168.5.2, prot= 47
2691Router#                          sh crypto isakmp sa
dst             src             state          conn-id slot status
192.168.5.2     192.168.5.3     QM_IDLE             38    0 ACTIVE
2691Router# sh cry
2691Router# sh crypto ipsec sa
interface: FastEthernet0/1
    Crypto map tag: MYVPN, local addr 192.168.5.3
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.5.3/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (192.168.5.2/255.255.255.255/47/0)
   current_peer 192.168.5.2 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 3646, #pkts encrypt: 3646, #pkts digest: 3646
    #pkts decaps: 4, #pkts decrypt: 4, #pkts verify: 4
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 1, #recv errors 0
     local crypto endpt.: 192.168.5.3, remote crypto endpt.: 192.168.5.2
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/1
     current outbound spi: 0x28553A1D(676674077)
     inbound esp sas:
      spi: 0x2BD49D31(735354161)
        transform: esp-des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 2002, flow_id: AIM-VPN/EPII:2, crypto map: MYVPN
        sa timing: remaining key lifetime (k/sec): (4449766/1872)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2001, flow_id: AIM-VPN/EPII:1, crypto map: MYVPN
        sa timing: remaining key lifetime (k/sec): (4449739/1872)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
How can i fix the log on 2691 router .
Also how can i tell which side is doing encryption and which not ?
Many thanks
MAhesh
28 Replies 28
hi andrew, i said that because i don't see any crypto map applied to the tunnel interface, the crypto map is applied to the f0/1 which is used as the tunnel source, to my understanding tunnel source only pull the ip address information from the source, not all the attributes of the source, this is why i recommend him to apply the crypto map directly to the tunnel interface, correct me if i am wrong,
Crypto-map cannot be aplied to the tunnel interface. It doesn't make sence. Its applied to phisical interface, and specifies that all GRE traffic, that goes through that interface (i.e. tunnel traffic) should initiate IKE exchange and IPSec tunnel establishment. This is because traffic that destined to tunnel interface first gets encapsulated into gre, and then forwaredt through phisical interface.
it seems that crypto map should be applied on the tunnel and the physical interface, please see documentation below for an example: http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009438e.shtml
Dear rudy. I've no idea why its applied on tunnel if in that doc (maybe it was so in older IOS versions - doc date is 2008 or smth else) but applying cryptomap on phisical interface is enough. Try it in GNS, if u haven't yet, and u'll see.
let's forget the old ways and use the new ways let's see if this can help Mahesh solves his issue,
That's what i started with)))
Hi Andrew,
Thanks for all help so far.
I removed crytomap from both sides  physical interfaces and did as you said earlier.
Now OSPF  nei adj is there between tunnel interfaces.
2691Router#                      sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
3.4.4.4           0   FULL/  -        00:00:31    10.5.1.1        Tunnel0
But now no isakmp running
2691Router#sh crypto isakmp sa
Other side
3550SMIA#sh ip ospf nei
4.4.4.4           0   FULL/  -        00:00:33    10.5.1.2        Tunnel0
Now OSPF adj is up from both sides.
What should i do next ?
Mahesh
Hi Andrew,
After doing this my internet access from 3550 was working fine but after sometime from 3550 i am unable to  ping internet
sites.
from 2691 i can ping the internet websites
3550
3550SMIA#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
3550SMIA#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.5.1.2 to network 0.0.0.0
O    192.168.12.0/24 [110/1012] via 10.5.1.2, 01:13:32, Tunnel0
     100.0.0.0/32 is subnetted, 1 subnets
O       100.100.100.100 [110/1002] via 10.5.1.2, 01:13:32, Tunnel0
     3.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O       3.3.3.3/32 [110/1001] via 10.5.1.2, 01:13:32, Tunnel0
C       3.4.4.0/24 is directly connected, Loopback0
C    192.168.30.0/24 is directly connected, Vlan30
     64.0.0.0/32 is subnetted, 1 subnets
O E2    64.59.135.150 [110/300] via 10.5.1.2, 01:13:32, Tunnel0
O       4.4.4.4 [110/1001] via 10.5.1.2, 01:13:32, Tunnel0
C    192.168.10.0/24 is directly connected, Vlan10
     172.31.0.0/24 is subnetted, 4 subnets
O E2    172.31.3.0 [110/300] via 10.5.1.2, 01:13:32, Tunnel0
O E2    172.31.2.0 [110/300] via 10.5.1.2, 01:13:32, Tunnel0
O E2    172.31.1.0 [110/300] via 10.5.1.2, 01:13:32, Tunnel0
O E2    172.31.0.0 [110/300] via 10.5.1.2, 01:13:32, Tunnel0
O    192.168.11.0/24 [110/1002] via 10.5.1.2, 01:13:32, Tunnel0
O    192.168.98.0/24 [110/2] via 192.168.99.1, 01:13:32, FastEthernet0/8
C    192.168.99.0/24 is directly connected, FastEthernet0/8
C    192.168.20.0/24 is directly connected, Vlan20
     192.168.5.0/31 is subnetted, 1 subnets
C       192.168.5.2 is directly connected, FastEthernet0/11
C    10.0.0.0/8 is directly connected, Tunnel0
     192.168.6.0/31 is subnetted, 1 subnets
O       192.168.6.2 [110/1001] via 10.5.1.2, 01:13:32, Tunnel0
O    192.168.1.0/24 [110/1012] via 10.5.1.2, 01:13:32, Tunnel0
O*E2 0.0.0.0/0 [110/1] via 10.5.1.2, 01:13:32, Tunnel0
3550SMIA#
Mahesh
I think I know why it fails here.
A catalyst 3550 is a switch - not a router. Even if the parser command exists, they are not meant to work.
GRE for instance is unsupported.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3550/software/release/12.2_25_seb/configuration/guide/swuncli.html
Crypto map without a crypto engine [ which is the case here] is as well not supported. U should use a real router instead.
Cheers,
Hi olpeleri,
So You mean that GRE is not supported but IPSEC is supported on 3550.
As i am running IPSEC on 35550 and 1811W  without any issues.
Mahesh
U're lucky if it works....
Looking at the configuration guide... There is no references related to crypto.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3550/software/release/12.2_44_se/configuration/guide/swuncli.html
Cheers.
Hi olpeleri,
I enabled OSPF adj also between two physical interfaces and now from GRE tunnel  i am able to access the internet.
3550
4.4.4.4          10   FULL/DR         00:02:22    192.168.5.3     FastEthernet0/11
192.168.99.1      1   FULL/BDR        00:00:32    192.168.99.1    FastEthernet0/8
3550SMIA# ping 4.2.2.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/48/52 ms
Gateway of last resort is 192.168.5.3 to network 0.0.0.0
O    192.168.12.0/24 [110/13] via 192.168.5.3, 00:03:47, FastEthernet0/11
O       100.100.100.100 [110/3] via 192.168.5.3, 00:03:47, FastEthernet0/11
O       3.3.3.3/32 [110/2] via 192.168.5.3, 00:03:47, FastEthernet0/11
O E2    64.59.135.150 [110/300] via 192.168.5.3, 00:03:47, FastEthernet0/11
O       4.4.4.4 [110/2] via 192.168.5.3, 00:03:47, FastEthernet0/11
O E2    172.31.3.0 [110/300] via 192.168.5.3, 00:03:47, FastEthernet0/11
O E2    172.31.2.0 [110/300] via 192.168.5.3, 00:03:47, FastEthernet0/11
O E2    172.31.1.0 [110/300] via 192.168.5.3, 00:03:47, FastEthernet0/11
O E2    172.31.0.0 [110/300] via 192.168.5.3, 00:03:47, FastEthernet0/11
O    192.168.11.0/24 [110/3] via 192.168.5.3, 00:03:47, FastEthernet0/11
O    192.168.98.0/24 [110/2] via 192.168.99.1, 00:03:47, FastEthernet0/8
O       192.168.6.2 [110/2] via 192.168.5.3, 00:03:47, FastEthernet0/11
O    192.168.1.0/24 [110/13] via 192.168.5.3, 00:03:47, FastEthernet0/11
O*E2 0.0.0.0/0 [110/1] via 192.168.5.3, 00:03:47, FastEthernet0/11
3550SMIA#
But now 3550 shows that default router is physical interface not tunnel interfaces does this mean that GRE tunnel is not
passing traffic ?
MAhesh
I was having the same error in a lab simulation. I was looking for a reason of the problem and your contribution was exceptionally useful. I stopped having the error, and at the same time your answer helped me out understanding conceptually the use of crypto ipsec profile and tunnel protection ipsec profile commands. Thank you!
Thanks, Rudy, you solved my problem here at LAB.
