crypto isakmp command problem
fran19422
Hello, I cannot enter the command "crypto isakmp policy 10" on a 2801 router in config mode, running C2801-IPVOICEKP-M operating system.
The problem is the word isakmp. That is where the command fails.
I only have the options for "crypto ca,key,pki". There is no option for "crypto isakmp....".
Can anyone offer any suggestions ?
Thank you kindly.
johnlloyd_13
Level 9
Level 9
You'll need a Advanced Security
K9 image to supprt the said crypto command.
johnlloyd_13
Level 9
Level 9
