Crypto isakmp invalid-spi-recovery in a Cisco ASR1002-HX running EIGRP and DMVPN.
CSCO12789549
I have and ASR 1000 which is the main HUB for our EIGRP / DMVPN solution. I recently started getting crypto errors!!
*Apr 23 17:10:45: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=316.17.98.56, prot=50, spi=0x1872BAB4(410172084), srcaddr=80.76.167.70, input interface=Tunnel1 and
*Apr 23 16:54:40: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=214.13.90.244, prot=50, spi=0x6869FF33(1751777075), srcaddr=80.76.167.70, input interface=Tunnel0
I have 4 additional spokes no to sure if they are getting this error, but with terminal monitor enabled I am getting it on the main hub.
We also have 2 taclanes connected to the hub that branch off into the core. Hence I do not know where the 80.76.167.70 address is coming from.
Does anyone know how to clear this crypto issue from the hub?
Look at the workaround thread for reference :
clear manually SPI and test it.
https://community.cisco.com/t5/vpn/crypto-isakmp-invalid-spi-recovery-command-is-not-worked-fine-in/td-p/1531178
BB
marce1000
 https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/115801-technote-iosvpn-00.html
 M.
@marce1000 thank you for this link, it does give me some insight but even with the debugs running and with invalid-spi-recovery turned on I am still stuck as in what to do to clear this error up. The article does not go into full detail on how to resolve the issue. Any more suggestions? Thanks
BB
