Crypto map and VTI tunnel source on same interface
fbriski10
Hello.
What can I do if I have one interface facing the internet and it need to be tunell source for VTI and at the same time I should apply crypto map because
that router is easy VPN server? For example, is this configuration possible:
interface fastethernet 0/0
ip address x.x.x.x
crypto-map VPN
interface tunnel 0
ip address y.y.y.y
tunnel source fastethernet 0/0
tunnel destination z.z.z.z
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN_TO_BR
crypto ipsec transform-set VPN_TS esp-3des esp-sha-hmac
crypto ipsec profile VPN_TO_BR
set transform-set VPN_TS
crypto-map VPN
match address 101
set transform set VPN_TS
0 Replies 0
