02-18-2005 04:32 AM
This is to inform you that I have configured Dial on Cisco router1751/k9 when ISDN link goes down then secondary link should be dial automatically but it is not running any body could you help me
pk_iblqta_ra#sh run
Building configuration...
Current configuration : 4073 bytes
interface FastEthernet0/0
ip address 192.168.13.1 255.255.255.0
ip nat inside
speed auto
interface BRI0/0
bandwidth 64
ip address negotiated
ip nat outside
encapsulation ppp
dialer idle-timeout 2147483
dialer fast-idle 2147483
dialer wait-for-carrier-time 2147483
dialer string 13155555
dialer load-threshold 1 outbound
dialer-group 1
isdn switch-type basic-net3
no cdp enable
ppp authentication pap callin
ppp pap sent-username iblqtaisdn password 7 ***************!
interface Virtual-Template1
no ip address
interface Async5
ip nat outside
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 1
async mode interactive
ppp pap sent-username iblqta password 7 *****************!
interface Dialer1
description *** 56k DDP Connection To Brainnet ***
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 30
dialer pool 1
dialer string 13145679
dialer-group 1
no cdp enable
ppp pap sent-username iblqta password 7 ***************!
ip classless
ip route 0.0.0.0 0.0.0.0 BRI0/0
ip route 0.0.0.0 0.0.0.0 Dialer1 5
no ip http server
ip pim bidir-enable
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.116
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.118
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.25
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.254
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.252
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.136
access-list 101 permit ip 192.168.12.0 0.0.0.255 host 196.16.16.115
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.115
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.79
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.80
access-list 101 permit ip 192.168.13.0 0.0.0.255 host 196.16.16.81
access-list 110 deny ip 192.168.13.0 0.0.0.255 host 196.16.16.116
access-list 110 permit ip 192.168.13.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map brinat permit 10
match ip address 110
snmp-server community Wmhy6047msie RO
snmp-server host 196.16.16.254 Wmhy6047msie
banner motd ^CCThis computer system, its network and data contained therein is t
h
e
property of the International Brands (pvt) LTD. Access to this computer and
network is restricted to persons and programs authorised by the Group
only. Access by other is prohibited and unauthorised, and is wrongful
under law. Do not proceed if you are not authorised. Any unauthorised
access will be prosecuted to the fullest extent of the law.^C
line con 0
password 7*************
login
line aux 0
login
modem InOut
modem autoconfigure type usr_courier
transport input all
stopbits 1
speed 1200
flowcontrol hardware
line vty 0 4
login
no scheduler allocate
end
pk_iblqta_ra#logout
Thanks & Regards,
Muhammad Amir Sheikh
Network Administrator
Email:mamir@iblgrp.com
02-18-2005 06:17 AM
I assume that it does not work while BRI0/0 never goes down, it remains up-spoofing, even while there is no active connection.
Could still work if you shut it down but that is probably not the way it was intended to work.
Leo
